70-mile-an-hour Warning
Discussion in 'Gen 2 Prius Main Forum' started by Mark Hollis, Jun 2, 2013.
  1. Mark Hollis
    Mark Hollis Junior Member
    2023 Prius Prime
    XSE
    I was headed down CT Route 9 at about 70. Do this every weekend in my 2005 Prius. We're motoring along and suddenly the red triangle with the "!" comes up. The Check Engine light comes on, the break light comes on and the VSC light comes on.
    My wife pulls out the manual, which says "stop the car immediately and take it to your dealer." If you're stopping the car, you -cannot- take it to the dealer. The book suggests I won't have brakes. I had brakes. The car seems to be acting normally, save the gas engine appears to have slightly higher than normal revs and the cruise control will not activate.
    I finished my trip, about a 40-minute drive to the shore, parked the car, turned it off, turned it on and only the Check Engine and red "!" Triangle stayed on after it booted.
    On a Sunday, I am not taking it to a dealer -- they're not open and I can't get an appointment for several days. I have a very good Journeyman Mechanic (dealers staff with Apprentices) who just saw the car yesterday -- routine oil change. The car has about 130k miles.
    Anyone know what's up?
  2. -Tim-
    -Tim- Junior Member
    Low oil level, maybe?
  3. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    First thing is to check the inverter coolant reservoir, next to the inverter, while the car is in Ready mode. You should see turbulence on the surface of the fluid. If you haven't had the inverter coolant pump changed in the safety recall campaign, the dealer will give you a new one free of charge.
    Yes, check oil, but that should not affect the VSC system.
    Otherwise, you need to get codes read using a Prius specific reader, and list them here.
  4. Mark Hollis
    2023 Prius Prime
    XSE
    It will go into the shop tomorrow -- but I have a 40-minute drive home. Will check oil.
  5. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    nh7o had some good advice
    If you don't have inverter coolant flow, you shouldn't drive it until it is fixed.
    That is normally accomplished by using the services of a tow truck.
  6. Mendel Leisk
    42,367
    VSC equals Vehicle Stability Control. If it's the instigator, maybe the problem's not related to the main mechanical systems.
    Just from the title, are you thinking there's some correlation between the speed and the warning?
  7. Mark Hollis
    2023 Prius Prime
    XSE
    No, Mendel. I do this drive every weekend, and my speed varied between 60 and 71 because cruise control did not work. Limit on CT-9 is 65.
  8. Mark Hollis
    2023 Prius Prime
    XSE
    I am not sure what the inverter coolant reservoir is. Oil is fine,
  9. uart
    uart Senior Member
    4,220
    1,212
    Australia
    VERY likely the inverter coolant pump failed and the inverter overheated. Disabling the cruise control is a sure symptom of this.
    Jaquimo likes this.
  10. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    There are pictures in PC, if it isn't convenient for you to do a search where you are, maybe someone will find one for you.
    Here's one illustration, lets see of a Gen II owner can verify that it's correct
    First thing is to check the inverter coolant reservoir (Receiver tank), next to the inverter, while the car is in Ready mode. You should see turbulence on the surface of the fluid.​
  11. uart
    uart Senior Member
    4,220
    1,212
    Australia
    The reservoir with the pink fluid next to the inverter. (It's the higher one of the two clear plastic tanks containing pink coolant, the lower one is the radiator expansion tank).
    Place the prius in ready mode and wait till the engine stops (so that your observations aren't confused by vibrations), then remove the cap on the top of the reservoir and shine a torch down and look for the turbulence of the circulating fluid. If you see no turbulence then it's definitely not working.
  12. Mark Hollis
    2023 Prius Prime
    XSE
    No turbulence at all, like glass. Can I get home on this? 40-45 minutes.
  13. frodoz737
    frodoz737 Top Wrench
    4,809
    2,562
    33
    Do not drive it. Do not run it. Have it towed.
    xs650 likes this.
  14. uart
    uart Senior Member
    4,220
    1,212
    Australia
    How long has the car been off for Mark? If you're starting from cold and drive very easily then yes I think you can drive a bit, but be very careful. If you can avoid big hills or anything that uses a lot of inverter power, use only gentle acceleration, avoid EV mode and stop every 10 to 15 minutes for a break and let it cool, then give it a try.
  15. frodoz737
    4,809
    2,562
    33
    This is covered by the TSB in the US and I believe towing is included. Either way, bad idea. Would you do this with the engine coolant? Don't do it.
    sturgidson and xs650 like this.
  16. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I thought your post was worth repeating, so here it is.
  17. Mark Hollis
    2023 Prius Prime
    XSE
    Drove it home, then to my mechanic. The TSB probably does not apply here at over 100,000 miles -- it is about 126K presently. That mechanic just changed its oil Friday. The car ran with just the Check Engine light for the first third of the trip. Then suddenly Cruise Control kicked off and the Brake and VSC lights came on.
    I believe fuel consumption is not good with this happening.
    Now, I would like to complain: With the amount of great reporting in the '05 Prius, why would Toyota choose to be so bloody cryptic here. Ought they not just say what went wrong? They report tank mileage, charging status, all sorts of stuff. Why do the owners get left in the dark with these things?
    Apologies to those who don't like rants. This car has been 100% trouble-free since I bought it used at 49,000 miles. I count on it to perform flawlessly.
  18. nh7o
    1,686
    340
    Hawaii
    The safety recalls are for any Gen II, not a factor of mileage. The reason why others are recommending not driving hard is that you are in danger of overheating the inverter, which is a major job to replace, and is not covered by the the safety recall.
  19. frodoz737
    4,809
    2,562
    33
  20. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Driving it is just stupid. No inverter coolant pump means no inverter cooling. No inverter cooling means all the IGBTs inside will only have ambient air and passive cooling. This is a system that can run up to 260V and up to 120A.
    $100 tow ride (free if you have a service like AAA) versus a potential $4000 repair. When the inverter goes, you car doesn't go at all. The car says problem, listen to it!
    As already mentioned, safety TSB's are covered on any vehicle even if you have millions of miles. You just have a limited time from being notified to when it is still covered. This particular one should be good until the end of the year. But generally if you bring in a car a decade later, they still cover it. For instance my 1997 Honda had a recall for a CV joint. I brought it in last year on something completely unrelated and they still replaced the whole thing for free. Almost 200K miles and 16 years later, free repair.
