70 mpg with no charge
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Rainking, Oct 17, 2012.
  1. rockerdan
    rockerdan PiP Rocks!
    427
    83
    Wheatfield NY
    driving gently and keeping it under 35mph you will get alot of EV driving after battery is depleted. Did you watch your small EV light come on alot around those city streets? I did this quite abit yesterday and was surprised myself how good it does in HV mode around city under 40mph.
    But if you get over 40mph the mpg IMO seems to drop down closer the NON PiP range in hi 50s. I still think the Pip always gets at least 10mpg better then a non PiP all things being equal in HV mode....its due to the larger PiP battery.
    Dan
    52,888
    yes, i see 70-75 quite a bit around town with no plug juice. this was covered i a way back thread from the spring. gen III is more efficient than II and pip is even better.
  3. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Agreed. The GenIII can do 70+ on trips around town if the traffic is light and/or conditions are right.
  4. fuzzy1
    10,722
    No surprise, as the non-PIP can do this in the right city or low speed conditions too. I've had a number of round trip commutes, 36 miles with substantial hills, hit 72 to 76 mpg when the traffic conditions and stop lights and weather were favorable.
    Remember that 50 MPG is the EPA label, which is sharply derated from the CAFE tests because most drivers can't or won't drive like the CAFE test cycle. The non-PIP's CAFE rating is a bit over 70 MPG. Skilled hypermilers in favorable conditions have topped 100 MPG. A PIP with depleted battery should be able to produce similar results.
    F8L likes this.
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Prius PHV ICE warms up faster than a regular Prius. Perhaps that also helped with the 18 miles trip.
  6. Rainking
    Rainking Member
    164
    New York
    I figured out what was happening last night as I had to make another city trip run with no charge. This time I paid attention to the monitors. Because of the slow city driving, I was able to keep my energy usage bellow the half line which keeps it in EV. I am able to maintain this as long as I don't accelerate too hard, exceed 40 mph or of course, run out of HV battery. That is hardly the case as you regenerate while deceleration and/or braking. Does anyone know if the regular Prius behaves the same way?
  7. bisco
    52,888
    i'm not sure what you're asking here, but, you cannot keep it in ev if you have no charge left. yes, the regular prius behaves the same way.
  8. Adam Leibovitch
    498
    102
    The PiP has a bigger battery that is available in HV mode. When you run out of battery you go down to 0.1 miles range, but when your empty and recharge from going downhill, it wont show any EV range until it gets to 0.9 mi range. I think those extra 0.8 mi are available in HV. If you recharged to 0.8 mi from driving, but then used it up before it ever got to 0.9, you would never know, it would only show you HV mode.
    So one difference might be that when the regular prius has charged its battery, it will stop, and the PiP can keep harnessing the generated power decreasing the need to use the ICE.
  9. terpsmandan
    terpsmandan Member
    144
    The battery in the PHV is never fully depleted because the computer will not let you fully discharge a li-ion battery. Once you have used up the EV mode there is still enough power left to let you drive under 40 just like a regular prius.
