700 Mile Club
Discussion in 'Gen 3 Prius Fuel Economy' started by F8L, Jul 16, 2012.
  1. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    You could have easily made 800 miles.
  2. Starship_Enterprius
    Starship_Enterprius Active Member
    334
    163
    Ottawa, Ontario
    2018 Prius Prime
    yup, I agree with cproaudio. If you were willing to risk going empty (bring an extra can of gas just in case), you could've made 800 miles. Good job!
  3. delayflight
    delayflight Junior Member
    Honolulu, Hawaii
    Broke another personal record. 10.5 gallons of gas. 100% eco mode, no A/C, 50% freeway, OEM 15 inch tires. When I got to gas station, last bar was blinking with 6 miles cruising range.
  4. Starship_Enterprius
    334
    163
    Ottawa, Ontario
    2018 Prius Prime
    congrats!...:eek: you are not too far from making the 800 mile club
  5. Robert Holt
    Robert Holt Senior Member
    1,313
    890
    Congrats +1 !!
    You have already gotten closer to an 800-mile tank than I have so far!
  6. EthelMertz
    EthelMertz New Member
    North Carolina
    Wow, I am subscribing. Great goal to have. I need to learn the tricks and tips though. I average 51.7 mpg right now and I know that is not very high, but I am on week two with this car so I am learning.
    Robert Holt likes this.
  7. Prodigyplace
    12,715
    11,848
    Central Virginia
    You can work on it, but summer is a better time to try & reach the goal. Winter weather & winter blended fuel tend to hurt mileage.
    Robert Holt and EthelMertz like this.
  8. Robert Holt
    1,313
    890
    +1 to having the right conditions to try these senseless tricks.
    I personally would like to try:
    Late Spring early Fall weather with temps in high 60s but not hot enough to require AC or windows down.
    Low rolling resistance tires inflated to 40-42 psi.
    Non-ethanol, summer blend, non-RFG gasoline.
    Tailwind of hopefully 15-20 mph.
    High altitude (5000-10,000 feet MSL ) but level route with smooth pavement.
    No rain.
    No traffic.
    Have achieved 700, but to get 800 I think I need to have an indicated mpg of at least 73 mpg on the MFD which would translate to a real 70 mpg which should get me to 800 if I overfill the gas tank up to the top of the filler neck with the car tilted to the other side. I think a steady 30 mph might do the trick, but that means well over 24 hours of steady driving. Good thing I'm retired!
    If all else fails, I'll have the DW push the car the last couple of miles!
    Peeto likes this.
  9. Peeto
    Peeto Member
    123
    55
    Slovakia
    I will keep you fingers. It is very realistic, just buy some LRR tyres, on 15 or 16" you can do it. Not even all of these points you mentioned must be met. I was very close to 800 miles even on 17" non-LRR tyres last summer and did 700 miles easily with high reserve.
  10. Peeto
    Peeto Member
    123
    55
    Slovakia
    Is it normal in winter, while it is -5 celsius, that I can squeeze out of battery only 1/4 of summer pure electric driving? Pips goes down very quickly. Looks like its normal. Overall consumption is not so bad in winter, like 4.5l / 100km if there is no snow.
  11. saltdiscus
    saltdiscus Member
    198
    89
    US
    Why does my milage sucks?I see 9 bar battery when I turn in my car.Is that normal?
  12. Robert Holt
    1,313
    890
    My impression is the same as yours: battery runs down more quickly in cold temps.
    My opinion is that both the chemical reactions in the cold battery are less efficient, and that rolling resistance is higher due to stiffer rubber in the tires, stiffer grease in wheel bearings, and more rotational resistance in things like the constant velocity joints. Possibly another small effect is increased air density at cold temps that would increase aerodynamic drag, also.
  13. DJ Q
    DJ Q Junior Member
    Trinidad & Tobago
    Finally broke this barrier a few weeks ago...
  14. Ferls80
    Ferls80 Performing some hypermiling techniques.
    66
    50
    Padova, Italy
    Well done
    Keep up the good work
    G8341 ?
  15. Triparadox
    Triparadox Active Member
    201
    108
  16. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    Probably not USD, seeing he is in Trinidad or Tobago.
  17. Robert Holt
    1,313
    890
    Congratulations! Welcome to the 700-mile club!
  18. Triparadox
    201
    108
    Looking at the language setting. I feel like he's in Japan. Then again, I wonder why the currency is in dollar.
  19. fuzzy1
    10,710
    The Trinidad/Tobago dollar is about 14 cents U.S.
  20. Triparadox
    201
    108
    Holy cow.. that's a bargain.. it's the same as $2.66/gal then..
