700 Mile Club
Discussion in 'Gen 3 Prius Fuel Economy' started by F8L, Jul 16, 2012.
  1. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    True but that was a risky venture with family in the car! I added a disclaimer to the first page about safety. I would hate to see someone going for the gold and run out of gas in a bad area with a car full of loved ones. :(
  2. Murali
    Murali Junior Member
    Madison, WI
    My first 712+ miles with a tank of gas.
    Display in the car shows 64.6 MPG. Here are the different parameters.
    Average temperatures: 80 to mid 90 degrees F.
    City/Hwy Driving: 90% City and 10 % Hwy
    Average speed: 29 MPH
    Tires: Bridgestone Ecopia EP422 LRRs
    Tire pressure: 44PSI all four.
    Daily commute: 17.3 miles one way.
    Air conditioner in the car: On 80% of the time.
    Stereo: 100% of the time with my added 600 watt sub.
    Type of gas: 87 grade with 10% ethanol.
    Last pip started blinking at 676.6 miles on my way to work. I got back to home and went to the gas station (I am picky with where I fill gas in my car.)
    walter Lee and PaulHS like this.
  3. jsfabb
    jsfabb Active Member
    617
    156
    Medford, NY
    So, how many gallons did you end up putting in? My guess is about 11.0 gallons!
  4. Murali
    Madison, WI
    Yes, you are right on. 11.04 gallons before and 11.02 after (as you can see if you click on my Fuelly image).
  5. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Congrats, mozdzen! Welcome to the club.
    Are you going to try for the 800 club? ;)
  6. kalome
    kalome Member
    411
    72
    Arizona
    2016 Chevy Volt
    Ah, finally you can add me to the 700 mile club.
    After a long Arizona summer it finally cooled off starting a few weeks ago where I can drive without AC.
    The first 100 or so miles I hypermiled most of the time.
    For freeway driving I try to keep iMPG around 60-75 when going uphill for those short hills and pulse a little on the downhill to build speed back up.
    My speed on the freeway is mostly 60-65. Used AC.
    The remaining 550-600 miles - No AC, avoided freeways. I took alternate routes where I would use regular roads to where I wanted to go. P&G whenever possible.
    DWB whenever I could without pissing people off, which is tough. People love to race to a red light then slam on their brakes.
    I don't know how you guys do it. I always have at least a few cars behind me in different lanes when I am timing a light. At times I find myself gliding a little faster than I want to towards a light, which results in having to stop briefly at a red light.
    Time of the year: October 9-22
    Blinking warning light came on at 583 miles, driving 117.3 miles more after the blinking warning light.
    DTE = 0 @ 618.6 mph, driving 81.7 miles more after DTE-0
    Miles: 700.3
    Gallons Pumped: 10.836
    MFD = 68.5 mpg
    Calculated = 64.6 mpg
    MFD vs. Calculated = -3.9
    % Error = 6.04%
    Avg Speed: 26 mph
    Edit: error %
    Murali, F8L and Codyroo like this.
  7. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    Congratulations! One of the great things with doing this is that it will give you confidence in the distances you can drive your car. You are correct, it is hard to drive without brakes with people riding on your tail. But now you can tell people you can drive over 700 miles on your car between fill-ups (and very, very few cars can do this). Great tank and great average!
  8. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    You made it! Welcome to the brotherhood. :)
  9. kalome
    kalome Member
    411
    72
    Arizona
    2016 Chevy Volt
    Thanks guys!
    Your MFD *10 math and calculating my largest error % (6.6%) with my MFD at the time which was 68.2 gave me confidence that I wouldn't run out of gas. By your MFD*10 calculations I was guessing I would use 10.9-11g and using the largest error % I was thinking 11g.
    So glad it worked out.
    Codyroo likes this.
  10. Codyroo
    1,826
    515
    Pleasanton, Ca
    And using 11x displayed would have predicted DTE = 753.5. Your calculated would have you run out at 11.9 gallons * 64.6 = 768.7 (15.2 mile cushion which is ~ 0.25 gallons). Not that I would ever recommend running to 11x, but it really is close to your true DTE.
    The thing I like about 10x DTE is that you will be well past the flashing PIP start and past DTE = 0, but still have 1.5 gallons left (estimated 75 miles of range). So your heart won't race so much if you are 20 miles from home and want to fill up at your normal gas station.
    kalome likes this.
  11. kalome
    kalome Member
    411
    72
    Arizona
    2016 Chevy Volt
    Yes it's great. I'm glad you came up with it and shared it to the group.
    It is very helpful.
    Codyroo likes this.
  12. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    David is cool like that. :)
    Codyroo likes this.
  13. markabele
    5,084
    1,782
    Nebraska
    Totally agree with this statement! I took a recent road trip to Texas...if I didn't know exactly how far I could push my gas tank I would have had to stop to fill up earlier at a MUCH more expensive filling station. Having this knowledge saves you some bucks here and there which can add up to a fair amount over the long run.
    fuzzy1 likes this.
  14. MattPersman
    MattPersman Member
    110
    33
    Indiana
    I know this is not the time of year to be trying to hit the 700 mile club, BUT... I hope to join this friday or saturday. on the way home yesterday I got the flashing pip at 647.7. I thought I was going to have to wait until spring or summer to try for it but I should squeeze it out.
  15. markabele
    5,084
    1,782
    Nebraska
    That is pretty sweet when you can hit 700 in late fall.
  16. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Do it Matt! :)
  17. MattPersman
    MattPersman Member
    110
    33
    Indiana
    673.0 yesterday when DTE hit 0 miles. it will hit today I will take a picture. cold outside right now 25 degrees. I will be putting the winter tires on this weekend I suppose. but stay tuned for my 700 picture
    Codyroo likes this.
  18. MattPersman
    MattPersman Member
    110
    33
    Indiana
    so I tried to take the pic at 700 even but it didnt work while trying to drive :)
    details were at 647.7 it started flashing
    at 673.0 DTE hit 0
    today rolled past 700 on the way home. 69.0 at the time when the picture took for the tank MPG. 25 mph average.
    filled up right after that was 706.5 miles, took 10.371 gallons. 69.1 MPG average, 25 mph
    I think I can hit a 800 mile tank in spring/summer. with the cold weather it is hard to get 60+.
    PaulHS and Jaquimo like this.
  19. MattPersman
    MattPersman Member
    110
    33
    Indiana
    At the gas station last night just trying to keep out section busier
    Codyroo and F8L like this.
  20. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Impressive mileage for late Fall! Congrats, Matt! :)
