76.1MPG-New Record Tank after 5 1/2 years of driving
Discussion in 'Gen 2 Prius Fuel Economy' started by efusco, May 10, 2009.
  1. efusco
    efusco Moderator Emeritus
    19,891
    1,193
    Nixa, MO
    I'm at work and will update with the calculated numbers later today, but wanted to share my excitement about a new record tank for me.
    A bit under 2 years ago I had an amazing 72.3MPG tank at a tad over 600 miles and wasn't sure I'd ever be able to exceded that. And if so, by a few tenths at most. I was wrong.
    The planets aligned, the weather was in that perfect zone b/w not too cold and not so warm that you need the AC. I had no long trips and, unfortunately, was working so much that I didn't have as many short trips to pick up the kids at day care/school as I usually do. I also was working a lot of odd-hour shifts so the roads were often nearly empty of traffic and I could really maximize hypermiling.
    With 10% of a tank still showing on CAN-View I topped up this morning with ~20 miles on the trip meter after the last pip started flashing.
    604 Miles, 76.1 MPG on the Consumption Screen!!!:D:rockon:
  2. okiebutnotfrommuskogee
    okiebutnotfrommuskogee Senior Member
    1,813
    Tulsa, OK
    That's great. At the rate I drive, I'll never see anything like that. You might get even better mileage with a broken-in set of Goodyears.
  3. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Great work man!!!
    One of these days I'll find a great commute and try for such numbers. I bet it feels pretty darn cool. :)
  4. efusco
    19,891
    1,193
    Nixa, MO
    LOL!! I haven't forgotten...I'll call you soon, in fact I've got a few days off this week about picking them up.
  5. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    That's truly impressive.
    My mileage stalled at 55-56mpg for three tanks. Can't explain it. But this year my hypermiling commute route is more congested and road construction season is gearing up. This is causing more stop-n-go and a lot more battery-depleting, sub-7mph creeping. I measured a creep stretch of 4.3 miles on Friday. I fear this may become the norm as the summer wears on.
    I'll try to take a picture one of these days, but the consumption screen looks something like this:
    65 - 85 - 30 - 35 - 20 - 75
    In other words: starts good but then creeps for a segment on battery causing a good second segment. Then the engine comes off-n-on for a couple segments and then it's up to 45mph on a depleted battery and then back to better driving. Truly frustrating.
    So I applaud your mileage exploits. As much as I really hoped to beat 75mpg this year, I fear that I may have to hypermile vicariously through you.
  6. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Evan,
    Great tank! Thanks to the Mycanscan I found a route that works allot better. Although I am not using any vehicle monitor now. I am basically guessing at the proper 2 K RPM accelleration pedal postion, rather than having the orange block on the Mycanscan light up at that point. And on the highway I have to look off to the right for the consumption mileage indicator to know when I have dropped into SHM. The EEEPC/MYCANSCAN is not permitted here due to an unfair Illinois law (video screen vehicle monitoring dispalys are permitted, but not if they are on a multi-functional device even if the operator only uses the multifunctional device as a vehicle monitoring display while driving - ie , the Toyota Tuff-book approach to vehicle monitors is illegal in Illinois too, and GPS programs on laptops are also illegal for driving assitance) , I have been able to acheive better mileage with even less driving time than previously. Right now I am 3 days from refill (reflll at 2 nd Pip) and reading 66.5 mpg on the tank. And that has been driving through some heavy rain storms and more than normal lunch-time runs. Another advantage of the Mycanscan was engine temperature, which in weather above 50 F is not nearly as important for the 23 mile trips I do, and luckily its been that warm or warmer the last two weeks.
  7. spitinuri
    spitinuri Member
    317
    Very nice. I would have to drive very close to a semi to achieve that kind of mileage.
  8. efusco
    19,891
    1,193
    Nixa, MO
    I have a route that's ~70% rural roads with little traffic and few forced stops. It's quite hilly with some very steep climbs at times (but equally steep descents of course). My in-town/city is usually not too bad, but at peak hours can hurt me.
    I use an EBH at home and at work pretty religiously and had very few cold starts this tank (usually my kids' soccer and baseball practices). I've had the grill fully blocked until just the past week or two.
    Conditions were not "perfect"...there were some pretty cold days in the low 40s range, I had a few trips of under 5 miles, did a little bit of highway driving (but not much). But of the 600 miles I be 400 of them were under my "ideal" work commute route with a pre-warmed ICE and the ability to maintain good technique.
    I'm sure that 80mpg is possible with 70F temps and perfect route.
  9. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    Wait, you had 10% of the tank left and you filled up. Evan, you could have broken 700 miles. I am depressed.
    Wayne
  10. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    See Evan, you went and let Wayne down... tsk tsk tsk..
  11. JimboK
    JimboK One owner, low mileage
    2,817
    187
    49
    Chesterfield, VA
    What took you so long?? ;)
    Congratulations, nice job! Now, how 'bout an 80 MPG tank? That's my goal for sometime this summer. In fact, the current tank is sitting at 79 MPG with about 350 miles on it. That won't hold, however -- m'lady and I are making a road trip this coming weekend.
  12. daniel
    14,487
    1,518
    Spokane, WA
    Congratulations, Evan. I get 50 or 51 mpg on long road trips, and 45 or 46 mpg at home. But then, I just drive it. (Of course, most days I don't burn any gas at all. The Xebra gets around 3 miles per kWh.) 76.1 mpg is damned impressive!!!
  13. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I have to add my congratulations! I wish I could pull that kind of MPG on my commute.
  14. Tideland Prius
    16,206
    Congrats!! Converted, that's 3.09L/100km. Yeesh! I can only dream of those numbers even with the 2010's improved mileage. Well done!
  15. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    I assume the energy used for the EBH is negligible in figuring the fuel economy?
  16. efusco
    19,891
    1,193
    Nixa, MO
    Well, it does depend upon how you look at it. And it is a bit of cheating I guess, in a way. But my first and main goal with my Prius was to burn less gas, and the EBH helps me achieve that.
    But, in terms of total energy, you are probably right to figure it in as it's likely that I use MORE total energy by using the EBH. At home it's usually on a timer for 3-4 hours only, so that's pretty negligible. But at work it's on the whole shift and sometimes at home I leave it on during they day so the ICE is warm when I need to leave.
  17. Gadgetdad
    Gadgetdad New Member
    462
    Modesto, California
    Kudos!
    I've never done better than 55 or so due to short trips and the 16" Touring wheels. I'm glad Toyota dropped back to the 15" on the '10 models (save for the gnarly 17" on the TOL package). I'm on track to get the Gold Model @ hoping the sunroof doesn't suck the milage down so I can compete with you Hyper-guys!
    Lee
  18. patsparks
    10,664
    567
    Adelaide South Australia
    On ya Evan, well done, how ever I am a bit disapointed that you kept driving for 20 miles after the last "pip" on the gas gauge started flashing.
    You can't win mate. :D
  19. PaulHS
    PaulHS Member
    200
    SE PA
    Wow! That's a milestone to be proud of, Evan. With summer coming, it looks like 80mpg may be just ahead.
    I've had a 71.2 tank but you're in a whole 'nother ballgame.
  20. efusco
    19,891
    1,193
    Nixa, MO
    I've been married for 17 years (almost)..I realize I can never win. As others pointed out, I was watching CAN-View for my fuel level and knew I had at least 1 gallon left. Of course I'm not sure how much of that was usable. I figure I could have made it to work and back to my town to fill up, but wasn't really interested in pushing my luck.
