$7E8 $7EA Red Triangle Of Death
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by James Nakamura, Aug 22, 2016.
  1. James Nakamura
    James Nakamura Junior Member
    Knoxville
    OK this has happened three times to me with slightly different symptoms and could use some assistance. 2007 Prius. This happens after the car sits idle for a day or two. Replaced the small battery about 12 months ago and the big battery about 4 months ago. 185K miles.
    First time: car sat for most of the weekend. stopped at a stop sign, car produced the red triangle of death, the screen said the informative word, "Problem" and the car stopped dead. OBD reader said $7E8 and $7EA. Tried a jump and clearing the codes to get it working (not sure it needed a jump). Ran fine for a week.
    Second time: car sat for the weekend again. Stopped and got red triangle again along with the yellow exclamation point. Problem read on the screen but the car kept running. Clearing the same codes and it ran fine.
    Third time: car sat for about 2.5 hours. Got a check engine light and the car wouldn't start when I got in. Clearing the same codes once again and it ran fine after that.
    What's going on here?
  2. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    You need a scanner with Techstream software, like the MiniVCI, to get the real Toyota codes. Your scanner is not compatible with the hybrid ECU.
    Where did you get the replacement hybrid battery? Have you been hearing any fan noise from the vent on the right of the rear seat? Any drop in mpg?
    "First time: car sat for most of the weekend. stopped at a stop sign..." I had to chuckle at this--that's a long time to wait at a stop sign.
    'LectroFuel and James Nakamura like this.
  3. James Nakamura
    Knoxville
    Thanks, I'll look into getting one. I got the battery from Greentec Auto. I thought the service guy was pretty knowledegable so my confidence in the replacement was pretty high. Yes, my mileage has dropped a bit but I assumed it had more to do with a long drive where I was going at higher speeds for an extended period of time. I would guess I may be about 5-10% lower than what I usually expect. No fan noise, but I'll be honest I haven't been paying that close of attention.
  4. andrewclaus
    993
    326
    Golden, CO
    Better start contacting Greentec about their warranty.
    It sounds like some of the auto parts stores' scanners will read some hybrid codes for free, if you need quick confirmation. But you probably won't get the complete picture.
  5. James Nakamura
    Knoxville
    I contacted them this morning and were extremely helpful. They first asked for the codes before they can issue a warranty replacement. I have a Mini VCI on order and will go from there. Greentec's warranty is 18 months so that was a nice time cushion (bought 4 months ago). I'm hoping this will be the solution and I'll keep you posted on this thread.
  6. James Nakamura
    Knoxville
    Well, Techstream came up with no fault codes. Called Greetec and they suggested looking at the oil level and it was low. So far, so good but I'll keep an eye on things. This does beg the question: it appears that my Prius is burning oil. Probably at a rate of about 1 quart per 2500 miles. Cause for concern? I'm fine checking/filling it once in a while but is there a reason to think it may have a serious issue?
    Longinus876 likes this.
  7. andrewclaus
    993
    326
    Golden, CO
    It's a cause for concern if the "problem" light came on. You probably added about two quarts? There may be engine damage now, so keep an eye (and ear) on it. Many of these cars start burning oil in the mid-100K range, so that part's normal.
    The low oil alarm should not stop the car, as far as I know, so something else may be going on. Use the Techstream to check the battery health. Connect to the the battery ECU and look at the block voltages, for one thing. If they're more than 0.2 volts different, let Greentec know and send them screenshots. There are battery tests but I've never done them.
  8. James Nakamura
    Knoxville
    OK the battery check didn't indicate any problems. I checked the voltages and the difference between the highest and lowest value was slightly higher that 0.2 volts. I ran the battery down and got the attached values. I'm really not sure if this is considered a problem or not. My work develops products that are battery operated and I've seen far larger swings in battery voltage when a system is under load. Any thoughts?
    So far, no new instances of the Red Triangle (since adding oil) but I will be keeping an eye on it and report back.
  9. bikes4u
    bikes4u Member
    131
    39
    indianapolis
    I ran mine low on oil not knowing that it burned oil right after I bought it and the light would come on around a corner then shut off immediately with no other problems. I have figured out mine burns oil at the rate of 1 qt every 3k miles so I add 1/2 quart every 1500 miles.
  10. dolj
    dolj Senior Member
    8,631
    4,385
    Wellington, New Zealand
    That screenshot shows:
    Block 2 = 15.31 V (Highest block voltage)
    Block 10 = 14.98 V (Lowest block voltage).
    The difference is 0.33 V. Block 8 is on the low side too.
    In order to be meaningful, you need to record your battery voltages under load. If it shows the same block(s) going high under charge and low under load, then you have a problem. A healthy battery will constantly have random block high/low over time.
    To me that TS print indicates your battery is in need of balancing. If, after balancing, it still shows the same behavior, then you will be calling on Greentech's warranty. Unfortunately you will have to wait for the P0A80, P30xx codes to appear before Greentech will give you support under their warranty. Drive the car hard to speed up this process.
  11. James Nakamura
    Knoxville
    So far the battery looks about the same. I took a 1500 mile trip over the weekend and the Prius performed flawlessly. I checked the oil this morning and I'm down about half a quart. I think I'll be monitoring that going forward and if the battery acts up, I'll give Greentec a call. It seems that the battery may have issues down the road but the real culprit for all of the problems I had, was the oil level. Thanks to all!
