80 MPH = Less than 40 MPG on the highway
Discussion in 'Gen 4 Prius Fuel Economy' started by robsnyder20, Aug 16, 2016.
  1. 30 - 35 MPG
    3.7%
  2. 36 - 40 MPG
    22.2%
  3. 41 - 45 MPG
    29.6%
  4. 46 - 50 MPG
    25.9%
  5. 51 - 55 MPG
    11.1%
  6. 56 - 60 MPG
    3.7%
  7. 61 - 65 MPG
    3.7%
  8. 66+ MPG
    0 vote(s)
    0.0%
  1. TheSpoils
    TheSpoils Member
    304
    49
    New Jersey
    I would use the Trip A for tank reading. (reset at each fill-up). I use Trip B for Oil change interval (reset at each oil change). Use the flag reading occasionally if i am doing a new trip or route to a specific location. And the odometer is not re-settable and will display the fuel economy for the life of the car. Good Luck
    RCO and Coast Cruiser like this.
  2. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    The MPG display, right next to my main odometer, is resettable a
    by using the small button on the steering wheel.
    I've reset it to zero a couple times just to see what would happen. And after a short time it jumps back up to 62 MPG.
  3. JimboPalmer
    12,470
    6,871
    Greenwood MS USA
    The Prius may well have more horsepower than any car I ever owned before, It SURE has more torque.
    1963 Ford Falcon 90 hp
    1971 Ford Maverick 105 hp (not a wagon)
    1976 Mazda 808 Mizer 59 hp
    1977 Mazda GLC 59 hp (not a wagon) 19.5 1/4 mile
    1985 Ford Escort 86 hp
    1989 Toyota Corrolla All-trac 105 hp (first car purchased new)
    2001 Subaru Forester 165 hp (but like the Corolla it was AWD, which reduces hp to the wheels) 1/4 mile in 17.2 seconds
    2009 Toyota Prius 110 hp (not a wagon)
    2012 Toyota Prius v 132 hp 1/4 mile in 17.8, so the Subaru may have had slightly more hp at the wheels
  4. Blizzard_Persona
    1,787
    945
    Pa.
    2023 Prius Prime
    XSE
    The odometer Mpg is absolutely re-settable... I did it today after my first fill up since the dealer fill up.
    Not that I wanted to reset it at all, but all you have to do is go to the ECO screen on the big screen and hit the update bottom on the bottom right of the screen. That resets the ODO reading. Hitting the Clear button resets the ODO mpg anew also.
    I didn't realize that was the case and thought that screen was to be used for tank to tank or trip to trip resets but now I know it resets the darn ODO. I was planning on using that screen as a tank to tank for comparison purposes and you will notice that on the top right of said screen the is a BEST mpg block. That shows obviously the best "tank" or trip or however you decide to use that screen.
    The only way to never have the ODO reset would be to never "update" or "clear" that screen. Kinda mad that I did but I guess next tank I could always clear it out and start anew.
    RCO likes this.
  5. MrMischief
    MrMischief Active Member
    426
    443
    Denver CO
    a post from me taken from another thread....
    I know it's not directly answering your question because I had some other driving in there, but it's about 100 miles to cheyenne which is basically on the boarder of CO and WY. I don't remember off hand if the limit is 80 mph before you get to Cheyenne or not. But once past Cheyenne it's 80 mph and about 178 miles to Casper. Then another 178 miles back at 80 mph. So of my 484 miles about 356 of those miles were at 80 mph with a crap cross wind and I got 49.8 mpg. I would guess that the wind screwed me more than the speed.
    robsnyder20 likes this.
  6. TheSpoils
    TheSpoils Member
    304
    49
    New Jersey
    So the dash odometer is not resettable. I will try the mpg on the odo screen. Sorry u messed up your system with the reset on account of me
  7. robsnyder20
    robsnyder20 Active Member
    374
    301
    SW Florida USA
    Thanks MyMischeif for your post. I recently took a 40 mile trip with the prius and drove it faster and harder on the way back and was impressed at the MPG at driving at 80. I think I was at 45 or 46 MPG (computer calculated) when getting off the interstate this time 30 miles later but that was with 4 people, AC on LOW with all vents on and I punched the throttle getting onto the interstate. Ended up with 51 computer calculated in the driveway and got 60 MPG (70 - 75MPH) going up taking it easier on the trip up.
  8. CZsp01
    CZsp01 New Member
    16
    The faster you go, in ANY vehicle, the more you have to energetically move air molecules out of the way to make room for the vehicle going forward.
    Not sure why people find that surprising....
    Did you hear, they reduced speed limit to 55mph back in the days of Oil Embargo 1970s ? That's to save gas.
    A jet uses more fuel at 750mph than at 500mph.
  9. Blizzard_Persona
    1,787
    945
    Pa.
    2023 Prius Prime
    XSE
    ^^^And yeah if you actually drive 55 on the highway this is attainable :)
    -The above was my commute last week to work and is above distance with 9 miles highway @ 55 mph (I95) and a quarter city (Philly) and a quarter suburbs!! This was on a warm engine to be fair. Amazing!!
    CZsp01 and Michelle_r like this.
  10. wjtracy
    wjtracy Senior Member
    11,337
    3,596
    Northern VA (NoVA)
    Lots of variables to consider. Weight, fuel type, warm up stage, wind etc. Was reading in Wikipedia that Bob Beaman's long jump was possible 12-inch longer than normal in the thin dry air, also 2 MPH wind. It rained before the other guys got to jump. Note his jump was over 2-ft over the record, so it is still one of the greatest sports moments of the century.
  11. MrMischief
    426
    443
    Denver CO
    Well.... is that air speed or ground speed? And since it's a jet we should figure altitude into this as well because efficiency of 500 mph at 200 ft may be quite a bit worse than 750 mph at 40,000 ft.
  12. galownia
    galownia Previous master neon mechanic
    117
    73
    drive 180 miles round trip with average speed of 65+mph according to the odometer. I get about 57-60mpg all in in this situation
    There are about 20 miles that are 80+mph. On these, I average around 54mpg (odo), with air on, radio on, cruise control. I drive a Prius Two Eco.
  13. hb1148
    hb1148 Junior Member
    46
    56
    Jacksonville, Florida
    I drive slightly over the speed limit but I don't think I've actually hit 80 yet. Actually my typical speed on the freeway is probably around 70 and at that rate the mileage is usually around 62 MPG or so. Even at or above 80, I'd find it hard to describe mid-40s MPG as "terrible" in my opinion. My 2011 Mustang GT (modified) used to get about 12 MPG at that speed and that's when gas was a lot more expensive. :)
  14. dangrass
    dangrass Junior Member
    47
    Oakland, CA
    Seems very low. I just returned from a trip from the SF bay area to Jackson, WY and back. 58 mpg there and 62 back. Much of the trip was at 75 mph on highway 80 and through southeastern Idaho.
    More importantly, what app/hardware are you using to display all this cool data?
  15. dangrass
    47
    Oakland, CA
  16. CZsp01
    CZsp01 New Member
    16
    That's thinking too much, sir. Paralysis in Analysis and it overwhelms the thinking then shuts down the ability to draw conclusions.
    When you compare science tests, validity comes by holding all other variables CONSTANT. That means air pressure constant in this case. Remember PressureVolume=nRTemperature. Google pv=nrt.
    Here's a simple experience if you can manage standing by the roadway safely. The outward air draft you feel from a 30mph car is less than one at 50mph car. The air molecules got moved, by the same object, at Higher speed has MORE energy and you can feel/hear it. It costs more gas to do that, more gas than necessary to cover the distance at lower speed.
    Want to experience higher speed? Visit a NASCAR race track near you. You can then feel the air draft pressure of something moving way over 150mph (do wear ear plugs if you're new to this). While there, cars are similar in aerodynamics, pv=nrt is generally the same.
    And yes, it takes a lot more energy to go at speeds beyond the sound barrier.
  17. pakitt
    pakitt Senior Member
    2,173
    1,312
    Colorado
    Hi - totally missed this one - sorry! I was also not posting in PC since a couple of weeks due to parents visiting, lack of time, friends visiting, etc....
    I did drive a lot though. To test 80MPH (average?) I think I posted somewhere else back in Feb/March the result of tests conducted by Italian and German Auto magazines.
    If you mean, what I get driving on the German highways, I got with 122km/h // 76mph average on a distance of about 160km // 100mi, an average consumption of 6L/100km // 39mpg.
  18. el Crucero
    el Crucero Senior Member
    1,628
    699
    Inland Empire
    I drive 65 (the speed limit) and average close to 70mpg with my PIP depending on itinerary.
    If I drive in the right lane at 65, trucks come within 5 feet of my rear bumper and honk at me because they are going 70 when the speed limit for them is 55mph. If I drive 65 in the left lane, you guys come up behind me and honk and give me the finger because you are going 80 in a 65 mph zone.
    WHAT LANE AM I SUPPOSED TO DRIVE IN??????????
    xpcman and krmcg like this.
  19. krmcg
    2,592
    2,390
    Whittier, CA
    I go 60 in the slooooow lane and everyone is happy to go around me.
    RCO likes this.
  20. el Crucero
    1,628
    699
    Inland Empire
    You are not too far down the road from me. Try going 60 in the slow lane on the 10 freeway! Yes, the trucks will go around you, but they are so mad they try to clip your front bumper when they pull in and slam on their brakes! VERY DANGEROUS! Yes, they do have a "how's my driving" sign on the rear with an 800 number, which I call, but it does no good.
    I am now using my new smart phone to record when some of the speed racers pass me on the right going 80/85/90, I can capture their license number and then pan down to record my speed. The CHP might find that information worth "investigating". The highest speed limit in California, I am aware of, is 70mph.
    Now, I'm starting to get all worked up about this thread! Flame away! :mad:
    RCO, xpcman and krmcg like this.
