800+ Mile Club
Discussion in 'Gen 3 Prius Fuel Economy' started by F8L, Jul 25, 2012.
  1. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Hmmm.
    If you assume that the clean part is 100% de-novo, otherwise un utilized wind, and the PEPCO fraction is 100% dirty, the combo is 77% clean energy. Man, I would I jump at an opportunity for electricity that clean, and would have bought a LEAF instead of another hybrid 8 months ago. My grid option is 100% coal; and like you I have practical obstacles to putting up PV. So like you, I have concluded that I have to reduce electricity use. I'm getting there: although I still cook and heat water with electricity, I am down to about 7 - 8 kwh/day these past 3 months. I'm shooting for 3 kwh/day once I switch to NG for hot water.
    I think the real problem is that clean energy aggregators and green credits are usually a scam.
  2. walter Lee
    1,126
    376
    Maryland
    All electricity on the grid is bought in credit units (its like a mini commodities market -- which certain agents like Enron have manipulated in the past). FWIW - 100% of the money used to buy 1.0 kwh from "clean current" goes to financially supporting wind turbine farms in the USA (PA, OH are the two states that I remember) by buying credits from them directly. This in theory will helps them expand their wind farm operations. Its the best solution I could come up with given my circumstances. In defense of PEPCO, they have inherited a dirty legacy electric utility so its an uphill battle for them to be environmentally friendly - however, the criticism that PEPCO needs to do much more for environmental is not unfounded - especially given their high costs. PEPCO energy usage is as follows:
    · 52.3% coal
    · 35.3% nuclear
    · 7.9% natural gas
    · 0.3% oil
    · 0.3% hydroelectric
    · 3.9% renewable energy
    My current 12 month running average is 400 kwh/month (13 kw/day)
    My goal is get it to 300 kwh/month.. I'm still pretty wasteful... :rolleyes:
  3. SageBrush
    11,627
    2,533
    Southwest Colorado
    I bolded the key point here. I like my greenery to be more than theory. If I buy a kwh of green energy, then I want one more kwh of clean energy, and one less kwh of dirty energy, on the grid than was present before I handed over my money.
    'support' and 'help' are way too nebulous for me.
  4. walter Lee
    1,126
    376
    Maryland
    What you want is a choice which does not exist on the grid.
    All electricity that is bought over the grid is generated in real time in a commodity market structure - once the electricity is pumped into the grid there is no way to identify whether a particular kwh was made from clean or dirty energy -there is no way around this. It is the nature of all the electricity purchase via the grid. While purchasing from clean current pays for the generation of green energy, it cannot stop the generation of on-demand dirty energy directly - that's impossible without a federal mandate/law to dismantle/ convert the plants which are generating dirty electricity on the grid. For example, in Japan there is a political movement to dismantle the Fukushima Nuclear Reactors because of the damage they incurred after the earthquake and Tsunami.
  5. SageBrush
    11,627
    2,533
    Southwest Colorado
    In one respect I was being too literal. Assuming that demand does not increase by one kwh just because I bought/brought an additional one clean kwh of energy to the grid, I infer that one kwh of dirty energy less will be consumed.
    My objection to the 'green credit' plans I have looked into all sell me clean energy already on the grid, but do not add any more.
  6. walter Lee
    1,126
    376
    Maryland
    My contract requires clean energy unless there is an emergency of some sort.
    Only by creating a demand for clean energy can the market for clean energy expand.
    Unfortunately, because of my continual efforts to conserve electricity my
    annual need for electricity is dropping - so they're going to need more customers...
  7. Kore971
    Kore971 PEDD-CESC
    106
    59
    Downey
    Here is my best tank, which i just finished today!
    10.925 gallons added to tank by 813 miles driven would be about 74.4mpg, so it was about 1.2mpg off in the positive side...
    The last blip started flashing at 679 miles on the tank..
    So I drove about 134 miles on the flashing light
    I drive a 2011 Toyota Prius Five, Black
    Im running factory 17" wheels with oem Toyo Proxes
    Tire Pressures: 40 psi front 40psi rear
    I have a scanguage 2 which i monitor battery SOC, Engine RPM, Coolant Temp, and fuel cost per trip.
    I drive on the Freeway, and on the street, mostly freeways and i hit some spots of traffic on my way to work and on my way home
    I always have the car in eco mode.
    I drove 813.4 miles on 10.925 gallons
    87 octane fuel filled up at ARCO
    MFD average speed estimate = 28 mph
    MFD Fuel efficiency estimate = 75.6 mpg
    Calculated MPG at the pump = 74.4 mpg
  8. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Say that again. 17s? Holy Hell!
    Kore971 likes this.
  9. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Congrats, Kore971!
    I added you to the list. :)
    Kore971 likes this.
  10. Kore971
    Kore971 PEDD-CESC
    106
    59
    Downey
    yeap!!!
  11. Texas-Prius
    Texas-Prius One more Prius to fight terrorism
    79
    32
    Austin, TX
    Ok, I'm more than confussed now. 17s, mostly freeway miles, and stop and go traffic? Now I see that your AVS is 28mph, so one of the many questions that is going through my mind is: What speeds are you doing to on the highway? Do you have a pit crew waiting every time you come to a stop to push the Prius back up to speed again? Do you have one of those magical hydrogen generators hooked up to the ICE?
    I definately congratulate you for your incredible accomplishment, but I would like to know a lot more about yor 813.4 mile journey. It sounds like you may be applying a new trick/skill that the reset of us aren't aware of, and I for one eagerly await to hear more about this.
    - TP
  12. mrstop
    mrstop PWR Mode
    740
    329
    109
    Cincinnati, OH
    I thought there was some James Bond gadget that shot out a rope and grappling hook to the car in front. :ROFLMAO:
    I too am in awe and want to know your technique!
  13. kalome
    kalome Member
    411
    72
    Arizona
    2016 Chevy Volt
    "Do you have a pit crew waiting every time you come to a stop to push the Prius back up to speed again?"
    What happens is a giant hand emerges from the clouds, grabs his car and moves it while he is in neutral.
  14. slcMPG
    slcMPG Member
    221
    65
    SLC, Utah
    17s & 74 mpg and highway. Very nice. Must be using SHM.
  15. Kore971
    Kore971 PEDD-CESC
    106
    59
    Downey
    I never thought i would be able to accomplish this when i first bought the car. but for sure a lot of time behind the wheel helps, i drive 70 miles a day to get to and from work. Also precise management for exactly how much electricity i use while driving, and counting how long the engine runs (in seconds) helped a lot. I try to make sure that if I use the engine to accelerate for 10 seconds, i either coast or have the engine off for at least 20... Another thing is obviously avoiding short trips, and excessive acceleration in the pwr zone. Either way it was not easy and was very stressful to get those numbers without angering other drivers. I frequently switch lanes to allow people to pass me. But it was all worth it! :)
    walter Lee, Codyroo and F8L like this.
  16. markabele
    5,084
    1,782
    Nebraska
    Think I have an outside chance of beating my personal best this tank. I should have it completed by Saturday or Sunday.
  17. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Better than your top tank? No way! I can't wait to see what you pull.
  18. walter Lee
    1,126
    376
    Maryland
    That's great! :) Whatever your tank is - its probably going to beat mine. :p Traffics around the construction of the Naval Hospital expansion has been a real MPG killer on my commute - Just yesterday afternoon it took me 1 hour just to get out of Bethesda( from the Bethesda Metro Station to Rt.355 I270 exit, estimated distance = 2 miles) :( While I time shifted the morning commute (83 mpg) - my MPG gains was wiped out by the afternoon traffic jam in the afternoon commute going home(53mpg). :rolleyes:
  19. jsfabb
    jsfabb Active Member
    617
    156
    Medford, NY
    That puts you down here with us mere mortals! :)
  20. markabele
    5,084
    1,782
    Nebraska
    Got a new personal record!
    Temps have been 50-80 so I haven't had to use any sort of HVAC. Just standard around town type stuff. Actual was 74.7 which was 5.5% difference. That is a little bigger difference than usual. I used 10.954 gallons. This leads me to believe that next spring a 900 tank might be possible. We will see...
    Kore971, F8L and walter Lee like this.
