80831 Miles on Original Integrity Tires
Discussion in 'Gen 2 Prius Main Forum' started by MT-IL, Aug 29, 2008.
  1. MT-IL
    MT-IL New Member
    Today is the magic day to swap out my Integrity tires. I have 80831 miles on the originals. The car is just days past 2.5 years on the road.
    My lifetime is just a hair over 50.2mpg. I was going to hold off until closer to winter but discovered a screw in one of the tires when I went to the car today.
    I guess I can be happy to go over 80k on the originals. Hope the next set gets me close to that as well.
    :juggle: It seems Discount Tire is going to take the full 2 hours they figured it might be. I hope they are done before my laptop battery gives up.
  2. a priori
    a priori Canonus Curiosus
    3,083
    407
    23
    Chicagoland (West)
    OK. No need to leave us in suspense:
    Obviously, you drive many miles per year, so most of these miles must be highway?
    What tire pressure have you used?
    What replacement tires are you getting? (name/number and size, also -- please!)
    Congrats to you!
  3. MT-IL
    MT-IL New Member
    Most of the miles were Chicagoland tollway. For the first 75000 miles I had a 130 mile per day commute. Now I'm down to about 35 a day.
    I run them about 38psi, sometimes 40ish. I rotated them at 10k, 20k, 30k, 40k, 55k and 70k miles.
    I'm putting on the same tires again. It would seem 1:45 to 2 hours at Discount tire is giong to be more like 3 hours. Maybe they serve breakfast if I'm still sitting here in the lobby when the sun comes up.
    I planned on finding my best deal before swapping them. I feel like I may have gotten my "Best deal today" but wow have I been sitting here a long time. If not for the screw in the one tire, I'd probaby have made about 83k or 84k on these ones, then changed them out for winter.
    They're pretty worn out, but still good if not for the screw sticking out of the one.
  4. brick
    brick Active Member
    1,083
    78
    Upstate NY
    I would love to see pics of the tread at 80k. Must be pretty ragged.
  5. Silver 2008
    Silver 2008 Junior Member
    71
    Idaho
    Wow! You did better than me. I only went 3,328 miles before I got rid of my Integritys.
    Of course, it snows here in Idaho, so they weren't much good to me.
    I was thinking the same thing. I was picturing white string showing all around where the tread should be. LOL.
    Mike
  6. JamesWyatt
    JamesWyatt Señior Member
    348
    Allen, TX
    I salute you for your bravery.
    You must have driven on roads made from marshmallows.
  7. Patrick Wong
    18,200
    6,464
    You win the award for most miles logged on one set of Integrity tires, congratulations! I replaced those tires after 15K miles. It is fascinating to contemplate the very wide range of tire treadwear life experienced by Prius owners.
    Consider the wide mpg range reported on GreenHybrid: as high as the 70's, and down to the 20's.
    Hybrid Mileage Database - GreenHybrid
    Given the wide variability experienced with tire treadwear and mpg, I am wondering what variability will be demonstrated with traction battery life, now that the first 2G are approaching 5 years of age. I don't believe it is realistic to expect that the 300K mile life experienced by a handful of taxicabs will be realized by most Prius - that is like looking at Edna Parker who is 115 years old, and expecting all (or most) American women to reach that age.
    Oldest people - Wikipedia, the free encyclopedia
  8. bac
    bac Active Member
    863
    52
    Pennsylvania
    Well, 300,000 taxi cab miles doesn't really equate to your average joe's 300k miles for sure. They are extremely hard miles.
    ... Brad
  9. Patrick Wong
    18,200
    6,464
    Hi Brad,
    I do not agree that your statement is correct relative to the traction battery. Compare a taxi being driven 8 hours a day, 5 days a week to a very lightly-driven privately-owned vehicle. The taxi duty cycle may be much better for maximizing traction battery life (as measured by the odometer), compared to long periods of no use. One reason for traction battery failure is electrolyte loss - this is more likely to happen as the module seals age over time. So a usage pattern where a taxi logs many miles over a short time may be more advantageous compared to a privately-owned vehicle logging relatively few miles per year, over a much longer time period.
    We're seeing the occasional Classic traction battery failure being reported with a US population of only 53K units (see the Classic subforum for details.) The 2G battery design has been improved, but the 2G population is several hundred thousand units, so it will be interesting to see what happens in the next couple of years.
  10. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    300,000 miles is rare FOR ANY CAR FOR ANY REASON...
    its funny we talk about the traction battery lasting 150,000 miles and being inadequate somehow...
    when we look at the other benefits of the Pri, less gas, less pollution, less brake maintenance, less engine maintenance, etc...
    there have been reports of traction batteries being replaced under warantee after 30-60,000 miles, some after at 100-140,000 miles... but that is par for the course. we are not driving perfection (ya that's right, perfection HAS NOT BEEN INVENTED YET!!)
    what about things that other cars suffer from?... im sorry, but knowing all that i know after 4+ years of driving a Pri, i wouldnt have done a thing different....
    other than a PHEV or an EV, there is no other car in the running for me for general passenger use besides the Pri.
    anyway... back to topic,
    im approaching 32,000 miles on my OEM tires and am nowhere near replacing them. im guessing probably 50-60,000 miles or so. this being my 2nd Pri, my first had 31,000 on it before it went away with tires showing only slight wear as well
  11. 4G63
    4G63 I quit boosting
    147
    Aurora, IL
    impressive!
  12. Randall Rash
    Randall Rash Member
    149
    25
    Rockwall, TX
    I have the package #9 with Option A which I thought guaranteed the Integrities for 100,000 miles. I never thought that sounded possible, maybe it was 60,000. Has anyone had that option and gotten them replaced with less mileage under warranty?
  13. hill
    8,093
    Wow! ... that's over 65,000 miles more than our garbage Integrities, when ours were shot. That's got to be a record, because many here on PC have similar stories of woe as ours. Are you sure you don't work for GoodYear? :D
  14. ctbering
    ctbering Rambling Man
    1,650
    123
    Chicago Illinois
    I am confused as to why the Goodyear Interities are so poorly thought of among Prius owners. Is it the uneven wear, issues in rain or snow, poor rubber quality? Why is it that Toyota Dealerships use them on so many Prius? And will Prius owners be better suited to do frequent tire rotations and certain PSI's with them to avoid some of the problems?
    I have 3200 miles on them now and I keep looking for wear issues but I have only driven them through the summer. I am a little concerned now that the season shifts to poorer weather conditions.
  15. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    Why are they disliked? Let me count the ways:
    1) Poor wet traction.
    2) Nonexistent winter traction.
    3) Poor traction on gravel.
    4) Noisy.
    5) Poor handling.
    6) Long braking distance (traction issues again).
    Other than that, they are fine.
    On the plus side, the Integrity tires are inexpensive, light, and have fairly low rolling resistance. They seem to be adequate for drivers in dry climates, and for areas without snow.
    Tom
  16. Patrick Wong
    18,200
    6,464
    Here's what's good about Goodyear Integrity tires:
    - they are relatively inexpensive
    - rolling resistance is low from new, unlike some tires that need "break-in" before mpg will come back up to expected levels
    Here's what's bad about those tires:
    - relatively bad traction especially after 5K miles
    - relatively short treadwear life, my guess is that the average driver will get 25K miles of wear
    - relatively bad snow and ice traction
    See tirerack.com for a customer survey comparison between Goodyear Integrity and other all-season 185/65R15 tires sold by TireRack - the following table says it all:
    TinyURL.com - shorten that long URL into a Tiny URL
  17. ctbering
    1,650
    123
    Chicago Illinois
    Thanks Patrick..great site...explains everything.Terry
  18. stemchick
    stemchick Montana Rocks!
    46
    Jordan, Montana
    I think I have about 20k on mine....driving on Montana roadways (tried to stay off the gravel). Went to the dealership to have the oil changed and tires rotated (this is a 3 hour trip!) and they said I need new ones. Couldn't afford it that day, so I drove home, but now am looking for suggestions on Prius Chat as to what tires to get. Anyhow, I am amazed you got that much mileage on them. I am not a car person, but am amazed that I haven't had the car a year and am having to replace the tires already.
  19. hill
    8,093
    No kidding! a record worth congratulating.
    Ours were shot at under 15K miles.
    On the other hand, our Michelin hydroedges? With 65K plus miles, you can hard ly tell they are wearing.
  20. Vincent
    Vincent Don't Wait Until Tomorrow
    641
    31
    South Florida
    Let me add sleeping better with real tires on my Prius. 80K miles was about 70K mikes beyond my comfort level with the Integrities.
