88.9 MPG commute
Discussion in 'Gen 3 Prius Fuel Economy' started by PriUsr, Apr 18, 2012.
  1. PriUsr
    PriUsr Junior Member
    28
    New York
    I did a 88.9 MPG commute today, but nobody believes me - couldn't find my phone to take a picture.
    Is there some way I can get back the summary screen that appears when one turns the car off?
  2. Absolutly Red Hot
    155
    83
    91
    SoCal
    Man, I am glad I am not the only one taking pictures with my phone. My wife thinks I am obsessed. I just got 99.9 mpg going to the market 1.4 miles away. Not a long distance until you consider that I have a wife the 3 daughters, which means I got to the market almost every night.
  3. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    673
    179
    Vancouver, WA
    How far of a commute do you have? What type of driving? When I fill up my Prius at the Shell station 7 miles away I can be between 80-100 mpg for the first 5.5 miles until I head up the hill to my house. The best I've done after the hill is 69.7 mpg. My goal is to break 70 if I can! :D
  4. AZGeek
    AZGeek Semi-informed Member
    627
    144
    63
    Arizona
    Guys, superchargedMR2 is asking the right questions. While it is great that you get high mpg, IMO it's kind of meaningless without putting that mpg into perspective. I live in some foothills and get great mileage on the trip down, but give that back up on the return trip home. Heck, we can all get 99.9 going downhill. :D
    There is one fairly flat stretch of road nearby that has a 35 - 40 speed limit. I can usually get high 70's on a 5 mile circuit. Years ago I used this road to nurse 716 miles on a single tank, averaging 63.3 mpg. Of course that was a Gen II, but I am waiting to try this out with my Gen III (hopefully soon).:)
  5. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    Nope.
    You will just have to repeat the result :D
    That is an awesome result if 1, it was a round trip; and 2, the battery SOC is not lower at the end than the beginning of the trip.
    I hit 80 MPG *once* in my G2 Prius with the above qualifiers, but I had to start with a warmed up ICE.
  6. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    I agree with AzGeek. :)
    My commute this morning at 50deg was 47.8mpg over 48miles. The trip home at 70deg was 67.5mpg over 48miles........
    I did take a picture of the display after I got home today. *insert cheesy grin*
  7. fuzzy1
    10,172
    If this was on the Trip A or B mpg display, it will still be there when you turn the car back on. But turn it on only in accessory mode (i.e. don't press the brake), otherwise the engine will start within about ten seconds and quickly wreck the reading.
    I've had a number on round trip commutes (i.e. two warmup cycles and zero net elevation change, despite several thousand feet of total climb) in the low to mid 70s. But none happened this early in the year, when weather is still cold. Have patience, and keep practicing so that your skills are ready when the favorable weather and traffic conditions appear.
  8. Ferls80
    Ferls80 Performing some hypermiling techniques.
    66
    50
    Padova, Italy
    ohhhh yes man! You can! :)
  9. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Pics or it didn't happen.... :p
  10. SuperchargedMR2
    673
    179
    Vancouver, WA
    I've never seen a screen like that on my 2010. Is it new for the 12 or is it hidden on my 10?
  11. theprius
    theprius Junior Member
    34
    NY
    I don't think the 2010 model has this BUT I would like to know if we can do a software update on these!?!?
  12. PriUsr
    28
    New York
    The trip was about 44.5 miles total: 37 hwy; 6 slower speed hwy; 1.5 traversing a city grid.
    I think it might have been the warmest day we’ve had here for the year (80F). I left my destination a little after mid-day; for the 37 hwy miles the traffic wasn’t slow moving, my speed ranged btw 60-75 (trying to keep up with the flow), I was in power mode and also trailing other cars; I moved to eco when I got closer to the city and limited my speed to no more than 60; I actually hadn’t been getting EV to engage since I got the car, so I gave it a try towards the end of the trip and it was best EV run I had – did a few block and turned it off when I needed avoid impatient drivers.
    I didn’t set out with the intent of getting good MPG; I just wanted to get from point A to B, that’s why I was so surprised by the summary screen. However, I was following the driving advice posted here in the forum.
    I was playing around with the EV mode, so my SOC was def less than when I started. Whatever road incline there was during the route, I would say there was an approx. equal distance of decent – so let’s call it fairly flat.
    The first person I told didn’t believe me, so I thought that there might be some way to get/download past summaries and prove it.
  13. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    It is new for the 2012 I believe. It comes on when you turn off the car. It is in the same location as the MID on the dash. Unfortunately it only stays on for less than a minute and cannot be recalled that I know of. So you have to be ready with a camera before turning the car off.
  14. fuzzy1
    10,172
    After seeing a 2012 today, I now see that OP is talking about a different display, not available on my older car.
    But one way commutes don't count as much as round trips, due to elevation changes. An example one-way reading with a bit of elevation change is shown in my photo album: 91.3 mpg on a 100.1 mile segment.
  15. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Show off. :p
  16. fjpod
    fjpod Member
    419
    72
    New York
    I just had a 300+ mile trip from NYC to DC where I got 64 mpg. My average speed was 57 mph. I got lucky with light traffic, good weather, and mostly stayed in the right lane. The trick to getting 60+ at these speeds is to not accelerate into a hill. If I was doing 60 on level ground, I would slow to 55 going uphill, then speed up to 65 on the downside...IOW pulse and glide.
    No pics though...so I guess it didn't happen.
  17. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Actually, you're describing Driving With Load, where you maintain a consistent load on the engine (and in particularly avoid heavy engine loads) and allow the speed to vary with terrain.
    :D
  18. ccdisce
    ccdisce Active Member
    259
    187
    Stone Mtn GA USA
    Loading is Good and so is Efficiency.
    A Screen capture from Priidash. I have not seen such a high MPG in a while especially after my afternoon commute. Not much elevation change but I may have to ask to add a GPS elevation display
    http://inlinethumb26.webshots.com/49305/2481988720070670239S500x500Q85.jpg
    If you end up adding a Priidash sceen to you car please be carefull of all the eye-candy!!!
  19. Tideland Prius
    16,159
    It's new for 2012. It's basically a trip summary (a fully fleshed out version of the 1G Camry Hybrid's "Excellent" remark on the MID if you beat 6.7L/100km/35mpg for that trip).
    Oh and 70mpg on a trip is possible even at higher speeds if you use SHM techniques.
  20. fattymoocow
    fattymoocow New Member
    96
    Richmond, VA
    WOOAH. I just went on my first 2 hour trip (110miles) with my Prius and I was driving an avg 75mph but at the end of the trip, my trip display showed 52.x-ish mpg. I hope to one day see my trip display show a distance of longer than 50 miles with my consumption being in the 60s-70s mpg!! I can only manage 60ish mpg on my 11 mile daily commute driving at around 55-60mph.
    Jealous :) :D
