88C thermostat
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Abarnabe, Mar 24, 2025.
  1. Abarnabe
    Abarnabe Active Member
    172
    102
    Netherlands
    There seems to be no winter 88C thermostat readily available, so I' m thinking of removing the 82c wax capsule from the plastic housing and replace it with a 88c one, here are some pictures.
    Did someone already try this, or have pictures of a disassembled housing an its internals?
  2. ETC(SS)
    7,539
    Try going 'non-metric' in your search.
    I did this using freedom units of measurements and according to the googles OEM #143-0691, THT-018 is a 180-degree (f) thermostat.
    No idea whether or not it will fit inside the housing for a Prius, or even if it's a real number - and I will not comment on the wisdom of using a non-spec thermostat.
    Good Luck!
    Abarnabe likes this.
  3. Abarnabe
    172
    102
    Netherlands
    Ken1784 tested the 88c thermostat available in Japan for a couple of years without negative effects.
  4. Abarnabe
    172
    102
    Netherlands
    Stuff you can do to improve your winter mileage | PriusChat
    #4 Abarnabe, Mar 24, 2025
  5. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    As far as I understand, this was written about Gen2.
    In 2008, there was no Gen3 with its engine, which has a tendency to overheat the cylinder head.
    The thermostat provides protection against overheating. Of course, you can throw in 88C as an experiment, but the result may be unpredictable.
