8A Limited Current charging better for the battery?
Discussion in 'Prime Plug-in Charging' started by CarlB, Mar 24, 2020.
  1. CarlB
    CarlB Junior Member
    70
    67
    2020 Prius Prime
    I understand the Prime can be set to limit charge current to 8A for circuits of 10A.
    Question is: would this slower charge rate be better for the battery? I would think so, based upon usual battery "likes" and "dislikes."
    Overnight charging should still get a full charge, so I can't think of a downside.
    #1 CarlB, Mar 24, 2020
  2. Rob43
    Rob43 Senior Member
    1,373
    1,050
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    The Prime already charges up Way Below 1C, so it already charges up at a very slow safe rate.
    Rob43
    jerrymildred and CarlB like this.
  3. drash
    drash Senior Member
    2,600
    1,340
    Upstate NY
    XLE AWD-e
    The battery will see substantially more stress and heat for a longer period of time by discharging (running in EV Mode) than any charging rate. Your car’s charger is equipped with a lot of sensors capable of utilizing both heaters and the A/C during charging. The only thing that’ll appreciate the lower charge limit is the car’s AC/DC converter, NOT the battery.
    iPad ? Pro
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    What @Rob43 and @drash said. Toyota really babies these batteries. Coddles them, actually.
    CarlB and Rob43 like this.
  5. Rmay635703
    Rmay635703 Senior Member
    2,705
    1,730
    Somewhere in Wisconsin
    2013 Chevy Volt
    I would argue 16amp 220v charging is better for your wallet as the aid systems that waste juice don’t have to run as long making the charge more efficient
    #5 Rmay635703, Mar 28, 2020
  6. jerrymildred
    11,517
    14,171
    Tampa, FL
    Did you really mean, "isn't better for your wallet?" Looks like the kind of typo I usually make. ;)
    Raytheeagle likes this.
  7. Rmay635703
    2,705
    1,730
    2013 Chevy Volt
    Gotta live auto correct, hmm it doesn’t like the word love either
    Raytheeagle and jerrymildred like this.
  8. jerrymildred
    11,517
    14,171
    Tampa, FL
    :ROFLMAO: I make sure that auto correct is OFF with all my devices. My typos are all my fault. :oops:
  9. Mark57
    2,945
    2,740
    OK
    See the bottom of my signature in red . . . ;)
    jerrymildred likes this.
