90k Maintenance Required Soon , Checklist
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by frisco_prius, Jun 4, 2019.
  1. frisco_prius
    frisco_prius New Member
    Got the maintenance message popping up. Did a few maintenances around 89,500 miles or so. Just posting to see what you guys think , based on this check list am I good to just close this ?
    Few months ago ( ~88k miles ) I started off by calling the dealer , asked them from a quote and what the 90k service included. He listed a bunch of stuff I knew I was completely capable of doing.
    So around maybe 89,500 miles
    - I had the tires replaced ( just because I like new tires )
    - motor oil and filter replaced ( with Toyota brand )
    - and the engine air filter replaced.
    - frequently test for steering issues.
    - I've been checking the tires for irregular balding
    - replaced the 12v battery when I bought the car because it was dying ( maybe around 83k )
    - last I think the front suspension was checked by a body shop too ... had a front end fender bender soon after I bought the car
    Just wondering if i'm pretty much good to go and just reset the maintenance light?
    .. I've also been thinking ill just bring it to have the brakes pads done and check the alignment
    most likely doesn't need it but I like how new brake pads feel
    anyways thanks for any suggestions you guys might have,
  2. Mendel Leisk
    42,197
    If he's on the level, he's just reading from the Toyota USA Warranty and Maintenance Booklet. And doing that for yourself is a much safer approach, lol.
    (If you're missing that booklet you can download pdf. One source is Toyota Tech info, look under the "manuals" tab.)
    Extras I would consider:
    1. Change the transaxle fluid. Toyota USA makes not mention of this in the schedule. Best to stick with Toyota ATF WS fluid.
    2. Change the brake fluid.Toyota USA makes not mention of this in the schedule. Toyota Canada says tri-yearly or 48K kms, whichever comes first.
    3. Inspect the brakes, a full inspection. Toyota USA recommends tri-yearly or 30K miles, whichever comes first.
    4. Inspect the Exhaust Gas Recirculation pipe. This is one section of the EGR circuit that is readily accessible, will give you an idea what the rest is like. Toyota does not include EGR inspection and/or cleaning, but has acknowledge it can clog up in some Warranty Enhancement Program notifications. They all clog btw, and this will cause the engine to run hot, no bad things.
    5. Clean the intake manifold and install an Oil Catch Can.
    Watch @NutzAboutBolts videos here, lots of info:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    Good thread:
    EGR & Intake Manifold Clean Results | PriusChat
    Another:
    Oil Catch Can, Eliminate that knock! | PriusChat
  3. Mendel Leisk
    42,197
    Check the 12 volt too: age, at-rest voltage, and CCA if you can manage.
  4. frisco_prius
    transaxle fluid i'm not familiar with .. is that just on the transmission crankcase?
    I don't have a service manual just the few that comes from the dealer... not sure if it shows how to replace transmission fluid or transaxle fluid.
    as for the brakes i'll prob just get new pads from a mechanic and they can also check and do the fluid.
    and for the EGR pipe inspection and oil catch can ... the egr seems like easy and good to check. i'm not sure I need the oil catch can though. Im not really interested in installing extra things atm. Might be good for someone else reading the thread though!.
    okay, I've already changed the 12v battery like 6 months ago. with a new Toyota brand battery so its prob fine.
  5. bisco
    52,695
    welcome!
    tranny fluid is just a drain and fill. two plugs on the side. should be around a hundred bucks to have someone do it. lots of threads here, and youtube videos. check out @NutzAboutBolts.
    you should have gotten a maintenance schedule with the car.
    egr 'circuit' is important at your mileage, head gaskets blow when their clogged $$$$$
    again, see nuts youtube video
    lube the caliper slide pins while you're in there. cabin filter?
    Montgomery and NutzAboutBolts like this.
  6. Mendel Leisk
    42,197
    Yeah, Toyota's expression for the transmission.
    The excerpts I posted relate to the things I mentioned, are from the Toyota Repair Manual, aka Shop Manual, Service Manual.
  7. CR94
    CR94 Senior Member
    2,798
    1,231
    Northwestern S.C.
    That term has been used for decades for any brand combined transmission and differential.
  8. Mendel Leisk
    42,197
    Ah, didn't know that.
    CR94 likes this.
  9. frisco_prius
    ohhh nutz and boltz .. yeah I watched his video when I first bought the car to do the oil change.
    okay ill look into the egr circuit.
    the first one looks like alot more work... for something that might not even need to be cleaned
    is it this one ?
    or this one?
  10. bisco
    52,695
    both :(
    it's a crummy job, but someone has to do it. dealer gets over a grand. it's all labor. some folks have purchased a used one on eBay or salvage so they can just swap them out and take time cleaning the original
    Raytheeagle likes this.
  11. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Then you remember you have a pressure washer and resell your spare (y).
  12. frisco_prius
    Can someone get back to me on the EGR valve video?
  13. frisco_prius
    Are there any service manuals for the 3rd gen on this forum?
