90k service due - How much $$ for inspection only?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by puptst, Dec 31, 2014.
  1. puptst
    puptst New Member
    Hey guys!
    Would really appreciate if someone knowledgable can chime in. I've been digging around and trying to be more educated about car maintenance. Unfortunately, I'm completely ignorant and don't have the tools or space to do my own checkups. Easy stuff like replacing air cabin or engine filter I can do, but nothing that requires actual tools. Anyhow, its time for a 90k servicing and the toyota prius 2010 manual recommends a pretty long and intimidating list.
    A local car shop quoted me $400 for the 90k servicing
    I researched and realized half of the items on the list can be done by my local oil changers for $70 (the usual, change motor oil, check coolant and all other fluids, tire pressure, etc).
    The other half of the list then says:
    Inspection of:
    __ Automatic transmission fluid
    __ Ball joints and dust covers
    __ Brake lines and hoses
    __ Brake linings/drums and brake pads/discs 3
    __ Drive shaft boots
    __ Engine/Inverter coolant 4
    __ Exhaust pipes and mountings
    __ Front differential oil
    __ Fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses
    __ Fuel tank cap gasket
    __ Radiator, condenser and/or intercooler
    __ Steering gear box
    __ Steering linkage and boots
    Given that the car shop quoted me $400 for the total servicing, is inspection really worth the other $330?!!
  2. JC91006
    16,936
    8,647
    If your car is running fine, you can just continue with the oil changes and air filter changes until 120k miles. At that time you would have to do more of just "inspections". Save your money until 120k miles.
  3. puptst
    puptst New Member
    Thanks for your reply! The car seems to run fine, though i do experience a few times the rattling when starting up the engine that people described here: 1.8L starting rattle, knock, events | Page 23 | PriusChat
    Why do you suggest waiting until 120k? Is your rationale to replace the parts later anyways, and assume that inspections are ok (since I dont have any problems) and save the money later when I inevitably will need to replace?
    thank you!!
  4. JC91006
    16,936
    8,647
    At 120k, a lot of things need to be done.
    1. change coolant (inverter and radiator), this is listed at 100k miles but I do it the same time as the other stuff at 120k
    2. change spark plugs
    3. change brake fluid
    4. change transaxle fluid
    5. change 12v battery if more than 5 years old
    6. oil changes / air filter changes
    7. and all the inspections you listed at 90k
    TsKarma likes this.
  5. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Recommended service intervals should be tweaked by your driving conditions. Extreme hot or cold, dusty, mountains, stop and go, short trips, etc. put extra wear on components, and therefore dictate service sooner than normal conditions. There is no "one size fits all" for when you car needs service.
  6. JC91006
    16,936
    8,647
    Unless your are talking oil and filter, brake pad changes, there's nothing else that relates to driving conditions
  7. Mendel Leisk
    42,355
    I've long suspected that long list of inspections really doesn't get done, that it's largely included to keep the lawyers happy. Except for the brakes, which really do need periodic, thorough inspection.
  8. JC91006
    16,936
    8,647
    I actually think they do briefly look over your car and inspect it for further repair opportunities.
    Yakoma likes this.
  9. yothere
    yothere Junior Member
    22
    $400 for checking stuff?
    At the dealer, oil change + tire rotation + fluid top offs + checking everything will run about $80
  10. Mendel Leisk
    42,355
    It totally depends on what the inspection entails, and that could run the gamut. If for example, they did an in-depth 4 wheel brake inspection, plus a quick look-over other items, $400 would be reasonable.
  11. Yakoma
    Yakoma Active Member
    470
    125
    sss
    Exactly. They are serving themselves, and you, if convenient. Because it's a business. Don't look for altruism.
  12. lizardskin
    lizardskin Junior Member
    26
    Northeast USA
    The 90K service usually includes changing the engine and cabin air filters. My spouse had the dealer do this until I smartened up, read up here and do it myself (really a less than 10 minutes each job). The billed amount of these were about $75 each. Filters cost arounf $15-18 each.
    Now I just take my car in for oil changes and they always do the inspections and fluids for free. After all, if they actually find something to that needs servicing, that is really to their advantage since they'll make the money. If they don't look, they will never make money.
    And because they are reasonable, I am the one who asked for the PCV valve to be changed (105K - didn't need it, returned part looked pretty clean, could have waited b/c we have decent gas), transaxel fluid (@100K) change hybrid system & engine coolant fluid changed 100K (the fluids were not pink but was not black/dark grey either). I think I could have waited another 10K. (I think also the brake fluids too - I'd have to check my files, no - I didn't, so next visit I'll get it done).
    I am waiting until I **need*** the spark plugs changed instead of doing it specifically at 120K.
    #12 lizardskin, Jan 19, 2015
    Yakoma likes this.
  13. Epiphany2000
    Epiphany2000 Member
    126
    San Francisco Bay Area, CA
    If it has not been changed already, you should change out the transaxle fluid. It's an easy DIY job, and should not be very expensive for a dealership/private garage to do it, as it is a simple drain & fill procedure.
