94 octane gasoline = quieter ICE
Discussion in 'Prime Main Forum (2017-2022)' started by bb4srv, Jun 15, 2018.
  1. kens97uber171
    kens97uber171 Active Member
    177
    133
    US
    I always find it amazing how little some people drive... LOL. Why even have a car.. just Uber everywhere if your using it that infrequently.
    I put 1000 mostly city miles a week on my 2008..when I'm working.
    Have 234,000 on the car.. I'm
    Just finished a 5200 mile road trip.
    Get out and drive it...
    Just my $.02
  2. Leadfoot J. McCoalroller
    8,293
    7,810
    Pennsylvania
    2018 Prius c
    When you're drinking that little coffee, I guess you get to know the flavor of each bean a little better.
    Congrats on the fuel cutback, looks like normal findings- there would be less knock with a higher octane fuel, and modern cars are programmed to almost-knock all the time.
  3. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    Ok, slick. Ease off the throttle a bit! It's mostly older folks that don't drive as much. We put in our time, and now we try to enjoy a nice relaxing retirement. But we still like to have a good reliable vehicle on hand. Uber sucks! :LOL: I only drive about 7,000 to 10,000 miles per year. The freeways are crazy, the big cities are crazy, traffic is crazy, and the speeders are insane! I'm considering a move to Mars. :ROFLMAO:
    Back on topic. I think using 94 octane is unnecessary, won't improve performance or quiet the engine, and is a waste of money. But you Prime guys hardly use the ICE much, so I guess it doesn't matter.
    #23 Starship16, Jun 16, 2018
    douglasjre, schja01, rcaine and 6 others like this.
  4. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Oh, and for the OP, don't take comments here personally. Keep posting your findings. We just like "ribbing" you (and each other).
    schja01, bisco and jerrymildred like this.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,171
    Tampa, FL
    My theory is that the high test fuel has fewer marbles in it, hence the quieter engine. :cool:
    Seriously, though, I can't see that 94 octane hurts anything but the cash flow, so go for it if you want to. I waste my money changing the oil in my PiP every 7,500 miles or so when half my miles are EV. ;) It's better than topping off your AGM battery with water, right? :ROFLMAO:
    #25 jerrymildred, Jun 16, 2018
    kenoarto likes this.
  6. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Don't think 94 should be quieter unless the orig fuel was so bad it was knocking. Even if there is residual water in the E10, it would be dissolved water so I would not expect a change.
  7. El Dobro
    El Dobro A Member
    7,106
    3,282
    My car is specced for 91 octane and that's what I use and I also use Top Tier gas. For the few extra pennies and the infrequency that I buy gas, why skimp. ;)
    Just go with what your car uses and stick with a Top Tier gas.
    #27 El Dobro, Jun 16, 2018
    Raytheeagle and Starship16 like this.
  8. ClemsonSteve
    ClemsonSteve Active Member
    270
    248
    South Carolina
    I washed mine last night and it is much quieter. When I wax it, I need a stethoscope to hear the engine —LOL
  9. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    Add a couple gallons of 94 octane, turn the lights off and put on some mirrored sunglasses and you may qualify as a stealth vehicle.
    douglasjre, bisco and kenoarto like this.
  10. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Without measurements from a meter, this almost certainly a classic case of the placebo effect.
    douglasjre and Starship16 like this.
  11. Starship16
    1,348
    1,455
    Beach Christmas
    I tend to agree that's it's a placebo effect. Same thing happened when I switched over to Mobil 1 oil. I thought my noisy engine was quieter for a day or two, but then the ol' growl came right back.
    I will be the sucker. This theory needs to be tested in a regular gas-guzzling Prius. You Prime guys rarely use your engine. Next time I fill up, I will pour in the hot 94 stuff and report back to you. Premium is currently only $4 per gallon at Chevron (US).
    #31 Starship16, Jun 18, 2018
  12. Dudley1030
    Dudley1030 Active Member
    200
    139
    Lawrence, KS
    I use a nitromethane/methanol mix. It also makes my 1/4 mile times much faster. You know, like the NHRA dragsters use. ;)
    douglasjre, benagi and kenoarto like this.
  13. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    It is HIGHLY unlikely that the octane rating of the gas you put in has anything to do with what you observed.
    Your car absolutely, positively will NOT benefit in any way from higher octane.
    The gas in your tank initially likely was 6 months old or more. Just getting fresh gas in there of ANY KIND probably would have had a similar affect.
    AND.....there is only so much you can do to prevent the fuel from going "bad".
    I think you should adjust your driving habits so that you use up most of what is in the tank at least every 6 months.
    Even then, stabilizer is a good idea.
  14. sam spade 2
    7,035
    2,804
    2017 Prius c
    Mid-grade might indeed be a "mix" but finding any grade that is E0 is still pretty rare.
  15. Leadfoot J. McCoalroller
    8,293
    7,810
    Pennsylvania
    2018 Prius c
    I'd agree with that... data from a knock counter or maybe something showing the spark advance averages for each fuel source would probably do it.
  16. Trollbait
    12,836
    ScangaugeII can report ignition timing.
  17. Dudley1030
    200
    139
    Lawrence, KS
    Love my Scangauge 2. I have two of them. Only one is updated to be able to report the tire pressures. That is why I bought it. However, the second one intermittently does not turn off. It has not been upgraded to the latest version. I also forgot to plug in the car. The older Scangauge has been left on in the past when it was plugged in and I never had an issue. I found out the hard way, Yes, it will run down your 12V battery and no you can not drive it with a dead 12V battery.
  18. Starship16
    1,348
    1,455
    Beach Christmas
    I got bored this morning. So I filled up (3/4 of a tank) with the highest octane grade at Chevron... It's 91 octane, here in California. I also washed and vacuumed the car. :)
    I can't believe the engine now. Total silence! :D Even the road noise disappeared! And my MPG jumped up to 199!
    ( I also have a cool mountain cabin I will sell you, in Death Valley, California. Cheap! :ROFLMAO:)
    #38 Starship16, Jul 7, 2018
  19. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    I bet it’s right next to the ocean front property:p.
    Starship16 and kenoarto like this.
  20. Fuel Miser
    Fuel Miser Junior Member
    86
    22
    Ontario, Canada
    I am still waiting for my 2018 Prime Technology (Premium) in Blue Magnetism to arrive. Currently drive a corolla and use 91 V-Power from Shell, and can tell you the car idles smoother, and responds better in the summer heat with it. The reason I use it is two fold. The better fuel additive package with upper cylinder lubricant keeps injectors and rings cleaner, and in the case of the prime will keep the EGR clean. The higher octane improves my mileage a tad because it has zero ethano, and this also leads to better low load idle qualitl. Only brand in Canada I know of that has a zero ethanol content.
    Am I blowing a bit more $ than I need? Yup, but he long term benefits outweigh this. On my last 2000mile trip my Corolla averaged only 5.2L/100
    or about 45 US MPG.
    Starship16 likes this.
