94 octane gasoline = quieter ICE
Discussion in 'Prime Main Forum (2017-2022)' started by bb4srv, Jun 15, 2018.
  1. Rmay635703
    Rmay635703 Senior Member
    2,704
    1,729
    Somewhere in Wisconsin
    2013 Chevy Volt
    It is common practice around here.
    Around here Premium is always a minimum of a dollar a gallon more at every station except Sams Club
    I just won’t ever buy Premium fuel and 92/93 octane is very rare as well to begin with
    99% of stations 91 octane is premium with a few 90 octane places
  2. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Off topic but I was looking for that video.
    That steep climb video is interesting in view of the Lion Air accident.
    The test pilot must have the anti-stall MCAS system disabled, I assume.
  3. Mendel Leisk
    42,352
    Card transactions are to the penny.
    Salamander_King likes this.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Is it also common to see mid-grade at a dollar more than regular ??
    THAT is what caught my eye in the original picture.
  5. Trollbait
    12,831
    Is all your premium ethanol free?
  6. Mendel Leisk
    42,352
  7. Rmay635703
    2,704
    1,729
    2013 Chevy Volt
    It’s about a 50% chance
    93 is never ethanol free 91 almost always is e free
    But 87 is efree at about 1 out of 4 outlets
  8. Mendel Leisk
    42,352
    How do you tell? You ask, they post on the pump, you test?
  9. Rmay635703
    2,704
    1,729
    2013 Chevy Volt
    It’s legally required on the pump but...
    In my area e free is a big deal, certain stations list all grades as e free right on the big sign
    Other stations list specific grades with ethanol content from zero to e85
    It’s pretty obvious what you get
    Heck there is even an online puregas gas buddy like site that lists e free and another that lists only e85
  10. litesong
    litesong Active Member
    371
    122
    Everett, WA
    Yeah, Wisconsin has 936 ethanol-free gasoline (E0) sources & comprises 7% of all the E0 sources in the U.S. & Canada.
  11. litesong
    371
    122
    Everett, WA
    The majority of limited available ethanol-free gasoline (E0) sources in Canada is 91 octane. British Columbia has quite a number of 94 octane E0 sources, along with other octanes of E0.
    #91 litesong, Dec 16, 2018
  12. litesong
    371
    122
    Everett, WA
    There ya go!
  13. litesong
    371
    122
    Everett, WA
    87 octane E10 blend is a wide octane spread of 114 octane ethanol molecules & 84 octane gasoline molecules. It is the 84 octane gasoline molecules that knock in an 87 octane designed gasoline engine. 91 octane E10 blend is a less wide octane spread of 114 octane ethanol & ~ 88 octane gasoline molecules, contributing to less knocking. Now, if you could have found & chosen 88 octane ethanol-free gasoline(E0), all the gasoline molecules would have been 88 octane & probably would have less knocking, been quieter & provided higher MPG.
    #93 litesong, Dec 16, 2018
  14. sam spade 2
    7,035
    2,804
    2017 Prius c
    That's an interesting theory.
    But individual molecules do NOT "knock".
  15. litesong
    371
    122
    Everett, WA
    Its mathematics: 10% 114 octane ethanol molecules, blended into 90% 84 octane gasoline molecules give a designated 87 octane E10 blend. Individual gasoline molecules may not knock, but millions of 84 octane gasoline molecules are knocking in every cylinder explosion in an "87 octane gasoline" designed engine. "samspade2" knew this, but had to squawk about "theory" & individual molecules, for some reason.
    #95 litesong, Dec 17, 2018
  16. sam spade 2
    7,035
    2,804
    2017 Prius c
    The reason IS......that the way you stated it is misleading and wrong.
    In normal operation, there is no "explosion"; there is a controlled burn.
    The mixture of different molecules helps prevent an explosion.
    Just the presence of nitrogen and carbon dioxide in the mixture tends to slow down the burn.
    And finally, "octane" is a measure of a characteristic of the whole fuel mixture.
    A single molecule does not have an "octane number".
  17. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    There are two methods to lab-test for octane, the Research Octane Number (RON) and the Motor Octane Number (MON). The U.S. and Canada post the arithmetic average of the two numbers...RON + MON ÷ 2...and call the result the Anti Knock Index (AKI). The AKI is posted on the pump. Other parts of the world use just the RON which runs 6 or 7 numbers higher for the same gasoline.
    The price spreads listed above for different AKI levels is just goofy. Here in the Seattle area we currently have $2.99/$3.19/$3.29 for the three grades of E10. The top grade is usually 91 to 93 AKI.
  18. Rmay635703
    2,704
    1,729
    2013 Chevy Volt
    It certainly isn’t uncommon
    Most stations charge about a quarter less for mid grade than premium,
    So $0.65-$1.00 more for mid grade is quite common.
    Only place that is sometimes bucking the trend is the Indian Casino, got gas for $1.99 a gallon today, noticed mid grade was $2.09
    everywhere else 87 was at least $2.17 on up
    Cheapest mid grade in town is at Sams club for $2.75 a gallon
  19. Mendel Leisk
    42,352
    We could probably clear up a lot of debt, be better off, if everyone used the spec'd gas?
    The percent of cars that actually need the higher octane is so low, and yet there the various options stand in a row, with equal billing...
  20. Salamander_King
    Salamander_King Senior Member
    11,024
    8,980
    New England
