9854-mile used oil analysis, oil change thoughts
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 1F7, Jun 9, 2023.
  1. bisco
    51,807
    yes, i have a hard time watching his long winded videos, which most videos are. i'd rather read a report
  2. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    The longer the video the more you tube can put ads in between. Can’t make money with short videos on youtube, single ad won’t bring enough revenue
  3. Noahdoge
    Noahdoge Active Member
    202
    144
    Mississippi
    I found some other videos that go more in depth and give better details.
    Edit: I think when it comes to oil changes, do whatever you’re most comfortable with. I personally think if you’re consistently driving highway or longer trips you’re completely fine to extend the oil to 7,500, or even further. I’ve had no problems from doing 10-11k oil changes for the first 140k. I personally stick with 5-6k miles now just because I want to keep this car as long as I possibly can.
    Breakdown of a Toyota engine
    very technical videos:
    #23 Noahdoge, Jun 11, 2023
  4. Mr.Vanvandenburg
    1,350
    569
    2020 Prius Prime
    Don’t do any oil testing and change the oil at 5k or less seems like a simpler way.
    Doug McC likes this.
  5. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Oil test takes less than 3 seconds to grab a sample for anyone. A lab coat person is not required to be present to do the work with pipets and swirling flasks.
    #25 Grit, Jun 14, 2023
  6. Paladain55
    Paladain55 Active Member
    404
    164
    The South
    Are we ignoring the fact that these cars will pass these oil test and still clog the rings? These oil test don't catch ring issues.
    Doug McC, Grit and Noahdoge like this.
  7. ColoradoBoo
    ColoradoBoo Senior Member
    1,227
    822
    Monument, Colorado USA
    I'd, also, be interested to see oil lab analysis after 10,000 miles of an engine run on the cheap, bulk oil the majority of car repair and even Toyota Service departments use. (Yes, they use OEM filter, NO they do not use the Toyota oil...I've asked numerous Toyota mechanics and service departments...if it's wet and slippery, they will use it.)
    I, also, change our Toyota's oil at 5,000 miles or 6-months (whichever comes first, sometimes that's only 2,000 miles). For our non-Toyota cars, they get changed every 3,000 or 6-months.
    Paladain55 likes this.
  8. Paladain55
    404
    164
    The South
    I also own a lot of vehicles and things that need oil changes. Here I do 5k or 12mo oil changes. The oil gets pretty stick with time as well. I find over a year will leads to getting down right sticky. 12 mo or less is doing pretty well.
    We changed one one time on a barn find car that was parked for 7 years. Oil was basically molasses.
