$999 HV Battery Replacement, Too Good to be True?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AnemoneSam, Mar 26, 2017.
  1. AnemoneSam
    AnemoneSam Junior Member
    Riverside, CA
    Hi Everyone,
    I need to replace an HV Battery in a 2005 Prius. While shopping around, I found the average price was about $2000 for a replacement using a 3rd generation battery. Then I found a mobile service that offers to replace your battery for only $999. Has anyone had experience with a service like this? I talked to him for a while over the phone. He said that his batteries come from crashed 3rd generation pri, they are balanced, and he does not mix and match modules. He has 3 5 star reviews on google and a 6 month warranty on the battery. Should I go for it?
    52,878
    first: name the company, so people here who have had bad or good experiences can chime in.
    second: go to his place of business, and make sure he has a legitimate operation that you are comfortable with.
    third: there have been good and bad reviews about mobile services, sometimes they come back when there's a problem, sometimes they don't.
    lastly: educate yourself on rebuilt batteries, it's always a crapshoot, and only as good as the warranty and company standing behind it. in 7 months, you could own a boat anchor, and be out $999.
  3. JC91006
    16,937
    8,647
    That is not that unbelievable, I could do it for half price. I also don't believe for a minute this person is giving 3rd gen modules from a wreck, not mixed and matched. Sounds like people like putting this info out there cause most can't verify
    milkman44 likes this.
  4. AnemoneSam
    Riverside, CA
    It is Affordable Hybrid Batteries of Tampa.
    It's a small business. He doesn't list a store front.
    I've tried to educate myself the best I can. Could I possibly check his work with an OBDII?
    Thanks!
  5. bisco
    52,878
    no. call todd at tampa hybrids, he's a well respected member here. i don't know if he does batteries, but can hopefully give you the low down.
    edit: are you in cali? is this tampa florida we're talking about?o_O
  6. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    I recall a scam deal where someone advertised "Gen 3" modules, but it turned out to be something like the number three batch of Gen 2 modules. Sort of shady, as I remember. If you can get the module serial numbers, you can easily find out on line.
  7. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    It's not too good to be true. It's a crapshoot. You may get lucky and the battery will last the remainder lifetime of the car. Think of it as buying a new car or buying a beater. A new car or a new battery will have warranty and most likely last you a long time. A used battery is like buying a beater because if it breaks down, it has no value whatsoever. The difference is a new car costs a whole lot more than a beater. You're getting quotes of $1000 more for a new battery.
    Everything I've read thus far is, you buy new if you're not a tinkerer.
  8. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    The critical question for me really is:
    Will the extra ~$1k you are going to save REALLY keep you out of some dire financial straits ??
    If you can actually afford the "going price" from a reputable business or dealer.......don't screw around trying to save a buck just for the fun of it.
  9. AnemoneSam
    Riverside, CA
    I ended up going to Todd at Tampa Hybrids. I Definitely think it will be worth the extra $1000! Knowing the history of a replacement battery really helps, and who knows what I would have ended up with if I went with the mobile service. Thanks for the advice everyone!
    mmmodem and JC91006 like this.
