A/C affect on Milage
Discussion in 'Gen 3 Prius Fuel Economy' started by ben12345, May 29, 2011.
  1. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    You know you are used to driving the Prius when you are disappointed in 42 MPG.
  2. Mendel Leisk
    42,243
    That's something I've thought: no matter what your ceiling and floor is, it's never good enough, LOL. The one thing that bugs me though is the con game Toyo pulls with ever optimistic in-dash display of mileage.
  3. mmcdonal
    mmcdonal Active Member
    666
    98
    16
    Columbia MD
    Gasoline is delivered in the Gulf states, and then pumped north in pipelines to other points, and then trucked from there. That adds cost.
  4. mmcdonal
    666
    98
    16
    Columbia MD
    I thought that if you use the ECO mode when running the AC, the car trims AC use for more efficient driving. Is that the case? I usually get the car cooled down, and then hit ECO for the rest of the trip (40 mph average speeds). Would that help Summer mpg?
  5. briank
    briank Solar Powered
    51
    Massachusetts
    I was going to ask the same question about ECO mode. I'm pretty sure I read on priuschat before that ECO mode does drop the AC compressor and fan power by ~40%. I try to use ECO when using A/C. In my limited usage so far I've only noticed a 1 MPG drop for a 50/50 highway/backroad commute, temps in the mid 80's and humid, AC set to 72
  6. Felt
    Felt Senior Member
    1,624
    604
    Mountain West
    I agree. OTOH, I have never owned a vehicle that was completely accurate.
    I have tried to understand why there is a difference. I bought gas today and both the calculated and indicated were EXACTLY the same. That does not occur often. On a recent trip, it varied from as much as 2.2 mpg. Historically, there has always been a few percentage points difference. You would think that Toyota could tweek the computer and cause the gauge to read correct. But, there must be more to the issue than a simple computer adjustment.
    Personally, I am convinved the gas pump is the cause of some variation. The densitity of the gas, depending on the tempwerature, is an issue we are told. And, no doubt, we fill the tank to slightly different levels of "full" with each filling.
    Is the difference constant, and the variation depends on how much fuel is added? Not sure. Would it read the same percentage difference if you added a gallon vs 10 gallons? I could check, but have not.
  7. Prius-it
    Prius-it Junior Member
    39
    Baltimore
    It's been hot past few days and my MPGs did go down to 47mpg from 52mpg. I've been blasting my A/C though. I'm impressed. Plus, I rarely do ECO mode because I find it dangerously unresponsive during my highway travel.
  8. Capt Ed
    Capt Ed Junior Member
    Indeed, I have found that to be the case. In A/C Auto mode, entering the ECO driving mode cuts the a/c fan speed in half. I do not know what effect it has on the compressor, if any.
    Ed
