A/C amplifier location
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by surfingnowaves, May 8, 2018.
  1. surfingnowaves
    surfingnowaves New Member
    Norway
    Hi
    Where is the A/C amplifier located? Local service told me that it needs to be changed and I need to figure out if I can change it myself. I am actually hoping to find a used replacement by getting to it first. Thx for the help
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    compressor?
  3. ChapmanF
    19,060
    Pull off that cover panel by pulling the rear, vertical, edge toward you (i.e., outward, toward the car door), then slip the panel rearward so its forward tongue comes out of the forward slot.
    -Chap
    #3 ChapmanF, May 10, 2018
  4. ChapmanF
    19,060
  5. surfingnowaves
    Norway
    so this is the story:
    Kid left lights on in the car and battery was drained. We tried to bumpstart the car with another car but as soon as the cables were connected (right poles!) the car started beeping. Tried few times, it was the same and we gave up. I called the road help and they could not start the car either so the car went to Toyota workshop. There some fuses and another part in the fusebox are changed. Since then the AC has problems. It is always off when I start the car which was not the case before. Previously, it would remember the last settings. The main problem is that it does not cool down although I switch the temperature to lowest. It only blows hot air. Same Toyota workshop checked the car and they said that amplifier (8865047080) is not giving out the right signals. They ask a lot of money (10+% of the market value of the car) to change it :)
    I have looked up some scrap yards for the part but they don't even know about the part. I called a Toyota workshop in Sweden and they said that they have never changed this part before... I am very unlucky it seems
    ivfx likes this.
  6. surfingnowaves
    Norway
    Cannot see the pictures. I have watched a youtube video where a guy uses a credit card to open them. I may try it
  7. ChapmanF
    19,060
    It pulls off easily enough with fingers; just observe the right direction of pulling, as described.
    I hope the mods can figure out what became of the images I attached. Probably still on my phone, but I don't have time right now to upload them again.
    -Chap
  8. surfingnowaves
    Norway
    Hey thanks. Do you think I can change it myself after removing the panel? Where is the AC amplifier exactly?
  9. surfingnowaves
    Norway
    I have changed it! And saved >$1000. Really grateful for your help ChapmanF
    First by luck I opened the thread on Safari on my mobile and the images showed up (still not showing on firefox on desktop)
    By further searching, found a used amplifier in Norway from a scrapyard
    Happy :)
  10. ChapmanF
    19,060
    Happy to have helped. (y)
    -Chap
  11. ivfx
    ivfx Junior Member
    36
    Dhaka Bangladesh
    You have to physically go and show them where the part is or show them the pictures here. I got the part for $40(Very dusty) at a salvage yard today. Mechanic is still working on the car right now. AC is still not working after replacing the amplifier a few minutes ago. Maybe soon InshaAllah...
  12. Alexlipine
    Alexlipine New Member
    Hi Chap,
    Any suggestions on easy replacement of the evaporator temp sensor on a 2012 Prius V, without pulling apart the whole dash?
  13. ChapmanF
    19,060
    That might be a tall order; I think the evaporator's pretty buried, and the temp sensor might be right on it.
    If you want to see if you can pioneer an approach, I would start by getting access to the repair manual (more info) and get really familiar with the drawings and access procedures, and see if there is a shortcut that jumps out at you.
    Alexlipine likes this.
