A/C Blowing Hot Air in a 2010
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ZBrink, Apr 5, 2017.
  1. ZBrink
    ZBrink Member
    81
    33
    Fairfax, VA
    My A/C started blowing hot air yesterday. I have it set on the lowest setting "LO" with the A/C button illuminated and the blower on full blast. Hot air on a wake day. It's a 2010 with 130k.
    Conventional wisdom would have me check for a Freon leak, then the compressor, etc. Is there anything specific I should look for because it's a Prius? Any common problem areas that cause this?
  2. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    check or replace the cabin filter first, than the basics, prii use special Freon and compressor oil..
  3. ZBrink
    ZBrink Member
    81
    33
    Fairfax, VA
    What is the "special Freon"?
  4. Beachbummm
    1,160
    392
    look up freon for hybrids
  5. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    I would check the A/C lines and leaks. touch the low side of the lines to see if its cold and the high side if its hot.
  6. ChapmanF
    15,662
    The first basic, so basic that nobody mentions it, is to hold down the AUTO and RECIRC buttons together while putting the power button ON, then read any two-digit codes from the temp display to see what your A/C says the problem is, if anything.
    -Chap
    ZBrink and Rebound like this.
  7. ZBrink
    ZBrink Member
    81
    33
    Fairfax, VA
    I had a shop check the pressure and there was no freon in the system so I had them put some dye in it. The photo below is me looking through the grill at the condenser with a UV light (blacklight). The green color appears to be the dye showing that the condenser is damaged and is leaking so I'm going to swap it out. The new one is on the way from Rock Auto. 20170410_155247.jpg
    Rebound likes this.
  8. NutzAboutBolts
    1,476
    1,552
    Bay Area
    Good work! make sure when the condenser is replaced, have the A/C system vacuum and recharge with Freon using a machine, don't use those A/C in a bottle to recharge since you need the system to be vacuumed dry and clean of any moisture in the system or else it'll cause corrosion in the lines and system.
    #8 NutzAboutBolts, Apr 10, 2017
    Rebound likes this.
