A/C blowing weaker on driver's side vs. passenger side
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by cnguyen11, May 10, 2020.
  1. cnguyen11
    cnguyen11 New Member
    Sacramento
    My a/c and heater blows stronger on the passenger side than on the driver's side. The temperature is EXACTLY the same, but the strength of air is not. Anyone else had this problem?
    Things I have tried but have failed to change anything:
    1. Closing the vents on the passenger side to see if it will blow stronger on the driver's side
    2. Changing the air filter
    3. Tinkering with the system that allows you to optimize where the air blows
    Please help!
    49,504
    stuck vent door maybe
  3. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    Do you guys have the Driver priority setting on your system ?
  4. cnguyen11
    Sacramento
    I don't believe I do. I have checked the settings for the a/c and it only gives front priority or full car
    kithmo likes this.
