A/C - bubble in sight glass
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by drive2much, Jul 6, 2010.
  1. drive2much
    drive2much Junior Member
    42
    Denver
    I'm having A/C problems. When I look in the sight glass then have somebody turn on the A/C, I see a bubble (air bubble maybe?) move along. Is it ok to have air in the system? Back when they used freon, I thought there wasn't supposed to be air in the system. Didn't know if it would be any different with the newer refrigerant.
  2. Patrick Wong
    18,200
    6,474
    The spec is for you to set the temp to MAX COLD and turn the fan speed to high. If you see bubbles in the sight glass and you feel the air conditioning is insufficient, then refrigerant should be added until the bubbles go away.
    A footnote in the repair manual indicates that if cooling is sufficient and ambient temp is high, then it is OK if bubbles exist. So there's some ambiguity.
    If you DIY make sure that you do not use refrigerant that contains compressor oil. Use of regular oil will damage the compressor permanently.
  3. koolingit
    koolingit Member
    158
    51
    Mocksville NC, USA
    You're right; the only thing that belongs in the circuit is pure R134 (in both a gaseous and liquid state. Before turning the ac on, the sight glass has no liquid in it, just gas. When you turn the ac on, the compressor raises the pressure on the condenser side of the system, heat is removed from the gas and the gas condenses into a liquid which then makes its way through the sight glass (that was the bubble you saw) to the evaporator where a metering device feeds the liquid into the evaporator at a reduced pressure and and the liquid starts to boil (at a low temp.) and absorb heat. Next stop is the compressor where the cycle starts all over again.
    I understand the correct charge for the prius is less than a pound of R134 and it's critical. The only correct way to charge the system is to evacuate it and weigh in the correct amount. You can't be that exact using the sight glass.
  4. okiebutnotfrommuskogee
    okiebutnotfrommuskogee Senior Member
    1,813
    Tulsa, OK
    Good work koolingit, That was a very accurate and concise explanation of what takes place with the refrigerant in the system.
  5. vertex
    vertex Active Member
    670
    143
    new york
    2018 Prius Prime
    When I fixed my car, I had to recharge the AC. After evacuating for 20 minutes, and checking for leaks, I filled it with R 134. I put in 12 oz and it barely worked. I then put in more while looking for bubbles & monitoring the low side pressure. When the pressure reached the limit on the scale for safe operation, I stopped, but there were still bubbles in the glass. The AC is working well, and is colder then any AC in a car I"ve owned recently.
  6. drive2much
    42
    Denver
    Thanks for all the information!
  7. Patrick Wong
    18,200
    6,474
    Note that the spec is 15.9 oz +/- 1.1 oz.
  8. hill
    8,187
    Our AC is nice & frosty on the hottest of days, and we got teeny bubbles ... so I haven't ever been bothered by it. It wasn't an intuitive call ... just lazy.
  9. Bear68
    Bear68 Member
    373
    72
    West Palm Beach, FLA
    Toyota's official stance is "charge by weight" in other words add the amount of refrigerant as specified for your model car. Bubbles may appear or not. Most newer Toyotas no longer have sight glasses. Use a set of gauges and a thermometer to determine if the charge is correct. Bear in mind that the pressures will fluctuate as ambient temp changes.
  10. vertex
    670
    143
    new york
    2018 Prius Prime
    I'm sure the 15.9 oz +/- 1 oz is for maximum efficiency. I am also sure there is enough safety margin in the design that you could tolerate more without damaging anything. What I should have done is weighed the cans before & after so I would know what I put in. Didn't think about it. I'm not going to pump it down, and charge it up again, so it stays.
    Refrigerant pressure gauges are the industry standard method of checking compressor operation, I don't see why that method is not good enough anyway. Bear68 says the same thing.
  11. koolingit
    koolingit Member
    158
    51
    Mocksville NC, USA
    If you're having to add gas to the ac, it means you have a leak. If the system is working properly, you never have to add gas.
    While your system is leaking, you'll be adding gas from time to time. Each time, you're adding a 'few ounces' to an existing charge that is unknown. You just keep adding a little till the suction line is beer can cold. Everytime you open the system to add gas you run the risk of contamination (air or moisture) getting in and that isn't good for any part of the system especially the compressor.
    I think it would be better to get the leak fixed, get the system properly evacuated and charged and be done with it. In the long run, it's cheaper than fixing the leak and replacing the compressor. But that's just me.
  12. Shahzad Nayyar
    Shahzad Nayyar Junior Member
    94
    23
    Pakistan
    Lately temperatures were reading around 39 - 43 celsius here in karachi. I have noticed that the sightglass has a few bubbles for the initial 5 seconds of starting the car. The bubbles then disqppear. Cooling is fine and chilly. Should i be worried? I have a gen 3 model 2015
  13. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    NO.
    If it ain't broke, don't "fix" it.
    Why are you even concerned the least little bit ?
    Note: The thread that you posted this question to is TEN YEARS OLD !!
  14. Mendel Leisk
    38,727
    That sounds normal. I've attached third gen Repair Manual info. And considering this is second gen forum, their info too.
    FWIW, the 2nd gen info (file that doesn't mention 2010) seems more understandable, for both gen's. My take there should be next-to-no bubbles as the compressor's running, then a swirl of bubbles just as it stops. If you run the system for a few minutes, and one of the tubes from the compressor (I forget which) is icy cold, you're good.
    More info from a Priuschat member, I took notes:
    From Priuschat member:
    @lech auto air conditionin
    Posting:
    Death toll risers for Prius electric compressors | PriusChat
    Subject: DIY check of Prius air conditioning state of charge
    (Not definitive, just to give you some idea)
    Works on a hot day say 80° plus with your vehicle in the sun set to fresh air mode outside not recycle all your doors open run your AC on high fan speed cold as possible but not max because that will set your air selector to recycle you do not want recycle selected.
    Run your air conditioning for about 10 minutes to let it equalize and stabilize on that 80° plus day. Now this is where people get hands burnt and fingers chopped by fans that turn on. If it could be safely done I put my hand all the way down on the suction line as it enters the compressor and it should be nice and cool.
    Under ideal conditions and if humidity was high you would see water condensating on all the surface of the metal line set the suction side going all the way back to the compressor. You cannot use condensation of water on the line if the humidity is low because it probably will not condensate because the dewpoint is too high.
    If the return gas line is cool the compressor and a electric windings like that cool refrigerant flow keeping the compressor happy with a long life and oil return.
    #14 Mendel Leisk, Jun 10, 2020
    Sonic_TH likes this.
  15. Shahzad Nayyar
    94
    23
    Pakistan
    So i measure the air being blown by the AC with Lo setting and fan at full speed. The minimum temperature i cud get was 8 celsius or 46 F. Is it good enough?
  16. sam spade 2
    7,035
    2,788
    2017 Prius c
    You are lucky it is that low.
    Whether or not that is "good enough" for YOU is another question.
    Honestly, many systems don't get that cold.
