A/C chage question? 30 PSI in normal range? whats my MAX?
Discussion in 'Gen 2 Prius Technical Discussion' started by Whitepriusguy1, Aug 4, 2016.
  1. Whitepriusguy1
    Whitepriusguy1 New Member
    san antonio
    Hey guys,
    Thanks for taking the time to read this, I have a small or big, not sure leak on my prius. I have to fill it up maybe once every 2-3 weeks.
    right now its sitting at 30 PSI , and there is still bubbles in the eye, is this a normal range? or whats the max i can fill the AC up to? I am also only using regular R-134 no additives. is there something i can buy that has leak fix that is safe? is there somewhere that sells the ND11 with the AC?
    forgot to mention i am getting 50 F on my temp guage
    #1 Whitepriusguy1, Aug 4, 2016
  2. Augustus88
    Augustus88 Junior Member
    87
    29
    Birmingham, AL
    Three Touring
    System pressure depends also on ambient pressure.
    For example, at 75 degrees ambient, your pressure should be around 40PSI on the low side with the compressor running. At 85 it should be around 50 PSI. 30PSI is the correct pressure for around 65 degrees ambient. You should never see above 55PSI on the low side with the compressor running. Please double check these numbers as well. I may be wrong.
  3. Whitepriusguy1
    san antonio
    ok, thanks for the reply, i will try that and see if i see any diff changes
  4. 05PreeUs
    05PreeUs Senior Member
    1,097
    563
    MSP
    You have a large, but not huge, leak in the AC system.
    The ONLY way to know if you have the correct amount in there, is to completely reclaim the system, evacuate to 750 microns and refill using an accurate scale. Unfortunately, that is pointless on a system that has a leak.
    Good news is that the most common leak points for AC systems are the service ports, but the Prius' seem to have VERY good systems.
  5. Mendel Leisk
    38,647
    This is third gen info, not sure how relevant it is. They don't mention ambient temp, and for low side spec. 21 to 36 psi as normal.
  6. 05PreeUs
    1,097
    563
    MSP
    Low side readings are more a function of humidity and charge quantity than anything else. Ambient is mostly irrelevant on the low side, as the air temp in the vehicle is the largest factor, as it cools the pressure will fall slightly.
    High side pressures are affected by the same and additionally ambient to a much larger extent.
