A/C Clutch - Safe Lubricant?
Discussion in 'Generation 1 Prius Discussion' started by Pri-Eye, Nov 4, 2015.
  1. Pri-Eye
    Pri-Eye Junior Member
    34
    Metro Detroit
    2001 Prius
    What lubricants, if any, are safe to apply to the A/C Clutch?
    Unfortunately, a junkyard sprayed PB Catalyst all over it before they sent it to me.
    station2stationautoblog-blogspot-com/2012/07/gen-1-prius-ac-clutch-diagnostics-and-html says that Brake Cleaner will cause the clutch's pulley bearing to seize.
    All comments appreciated!
    #1 Pri-Eye, Nov 4, 2015
  2. ChapmanF
    18,513
    Why are you replacing your clutch? It needed more than simple re-shimming for some reason?
    If you can re-shim the one you have, that leads to the easiest answer: just do that, and ignore the clutch you got from the salvage yard.
    Otherwise, I don't think there's much for you to do at this stage. If their spray didn't get into the bearing, then put it on and don't worry about it. If it did get in, then put it on and don't worry until it needs replacement again, then don't get the replacement from the same yard. You don't know which case applies, so don't worry about it. You'll find out if/when the bearing fails.
    If the bearing were to totally seize, it would mess up the snout on your compressor and that would be expensive, but I wouldn't expect that to happen without any warning. I'd pay attention to any developing noises in there ... don't just turn up the radio.
    -Chap
  3. Pri-Eye
    34
    Metro Detroit
    2001 Prius
    The car sat for a month and the A/C clutch and pulley rusted in place.
    Can I just remove them, clean up the rusted surfaces and reshim it?
    Anyone know if a belt from a Gen 2 would work to bypass the compressor temporarily?
    #3 Pri-Eye, Nov 5, 2015
  4. ChapmanF
    18,513
    Oh dear ... I guess that would depend on just what rusted to what and how badly. Where did the car sit?
    I have read on this forum of people doing exactly that.
    -Chap
  5. Pri-Eye
    34
    Metro Detroit
    2001 Prius
    It sat in a car port for a month. The Pulley and Magnet were rusted together. They can not spin after cleaning with a wire brush.
    I replaced the pulley, magnet and clutch pressure plate using new shims [88335-14020] and new snap rings [88365-87201 & 90099-07065].
