A/C cold while driving, warm while idling
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by OC63RAG, Aug 19, 2023.
  1. OC63RAG
    OC63RAG Member
    94
    42
    Hey everybody, I've searched and can't find the answer to this. My '07 A/C seems to function fine while driving (very cold, no issues) but once I slow down or am sitting in traffic it gets warm right away. The fans seems to be working fine (I can hear and see them running while the A/C is on).
    Are there general troubleshooting steps I should take to figure this out?
  2. Tombukt2
    Tombukt2 Senior Member
    13,627
    2,468
    Durham NC
    So look at the sight glass have someone else drive the car with the hood partially unlatched I do this so I can get it up quickly without having to wait for the person doing the driving to pull the lever but no matter. Have them drive up and down the street air conditioning cold now they come pulling up to you and stop you whip up the hood and look at the sight glass You got to do this fast. What do you see in the sight glass You may just be seriously under charge enough so that when the car is going down the road and plenty of air is coming in You're making what you think is enough cold and then as you slow the car down and there's not very much air coming through the front of the car cooling the gas it's performance plummets I guess this is possible The gas is a fine balance and that's what I would be checking first and then another check that's kind of easy to do is if you can get your hand up onto the condenser that's the part in front of the radiator that cools the freon after a good run and you pull in the driveway or over to the side of the road if you were to get where you can get your hand on the condenser is the condenser the same temperature more or less all the way across it are there any hot spots?
    OC63RAG likes this.
  3. theory816
    theory816 Member
    112
    23
    Get a diagnostic scan asap so that you can pin point down the issue quickly. If you let DTCs build up, it will be hard to pinpoint the culprit problem that is causing issues to other systems.
  4. rjparker
    rjparker Tu Humilde Sirviente
    10,694
    6,714
    Texas Hill Country
    Since it’s an electric motor driven compressor engine speed is not much of a factor. Both radiator fans need to run. A quality scanner can test their low and high speeds.
    Measure the vent air temperature while driving. A very good system that is cooling the car well may get down to 45f. Odds are yours is more like 65-70f. If so it’s low refrigerant typically although the condenser may be blocked or the metering device has failed.
  5. Tombukt2
    13,627
    2,468
    Durham NC
    If you don't run the air you shouldn't have any problems with DTCs until other things are failing besides the air conditioning it's not even on. I run cars for one or two seasons without the air working no matter till you try to turn it on and if it's connected to your computer system well you'll get notifications that it's not working or codes.
  6. theory816
    theory816 Member
    112
    23
    I'm just speaking in general. The main ECU does quite a good job at detecting any type of faults in any system. But if you let DTCs build up, it becomes more of a headache in diagnosing the main culprit.
  7. rjparker
    10,694
    6,714
    Texas Hill Country
    You can get a lot of duplicate comm errors combined with issues that are side effects of a root cause. Often experienced guys save current snapshots, clear everything and go from there. Bottom line is the best legal Techstream with interactive documentation and live links still requires comprehensive training of hybrid systems first. Which in most cases may be only one Master Tech per dealership and selected independents who often were trained at a dealership.
    The saving grace is most issues repeat and are seen often.
  8. OC63RAG
    OC63RAG Member
    94
    42
    If it us undercharged, is it as simple as recharging with one of the A/C recharge cans (type for hybrids)?
  9. OC63RAG
    OC63RAG Member
    94
    42
    It's not throwing any codes right now (at least through the normal warning lights).
  10. pasadena_commut
    pasadena_commut Senior Member
    2,935
    887
    Southern California
    AC cold when moving, hot when stopped, is the classic symptom for malfunctioning front cooling fans.
    OC63RAG and Tombukt2 like this.
  11. OC63RAG
    OC63RAG Member
    94
    42
    Is there a process for testing/troubleshooting the fans?
  12. Tombukt2
    13,627
    2,468
    Durham NC
    Yes ready the car put on the air conditioning get out of the car lift the hood after pulling the hood release. And the fans should be on by default when the air conditioner pump is pumping gas so if your air conditioning compressor is on you can put your hand on it feel the vibration there's no belt remember it's electric If it seems to be running touch the fat hose the metal silver line and see if it's getting a little cold If that air conditioning compressor is running the two front fans should be pulling air through the radiator and blowing back against your hand and then the engine pretty smartly You should hear them if they're running and you don't hear them but you can see that they're running they may be on their last leg meaning they need replacing because they should be running quite smartly and in between the engine cycling and the business going on you will hear the fans and feel the air if you stick your hand behind the fan or in between the fan rear and the engine front which there's no moving parts down there to hurt your hand none The grills are over the fans you can't get your hands or fingers in there generally speaking unless you're really trying and if you can't feel the air you need to find out why the fans are running too slow they may be clogged with crap in them they're not very expensive to begin with so if you're not in the third world country and have other choices it may be cheaper just to replace the fans or the fan motors as the case may be so if you're not in the third world country and have other choices it may be cheaper just to replace the fans or the fan motors as the case may be
    OC63RAG likes this.
  13. OC63RAG
    OC63RAG Member
    94
    42
    Thanks! I'll give this a shot once this storm blows through (SoCal). I have to change the oil soon. Is it easier to check the fans from underneath? I know looking at the fans from up top I can only see the passenger side fan.
  14. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Long shot here but.............
    You aren't in the habit of shifting to N when stopped or slowing down, are you ?
    The AC compressor runs off of the HV battery.
    If the system detects that it is getting weak, it might turn it OFF
    on purpose to conserve the battery.
    The HV battery will NOT charge when in N.
    That is a valuable thing to know when going through a
    "drive through" car wash too.
    OC63RAG likes this.
  15. OC63RAG
    OC63RAG Member
    94
    42
    Nope, I just drive it like a normal car (leave it in D).
  16. pasadena_commut
    2,935
    887
    Southern California
    It is pretty tight posterior to the fans. Rather than sticking a hand in there slide in a thin stiff piece of cardboard long enough to get down into the fan flow. Like the piece of cardboard on the back of a pad of paper. If the fans are going it will push hard on the cardboard, and if not, no push at all. It might be safe to stick a hand down there on a Prius but best not to get in the habit of poking one's hands in narrow spaces under the hood on running cars - there might be something spinning or hot you weren't aware of.
    OC63RAG likes this.
  17. OC63RAG
    OC63RAG Member
    94
    42
    That’s why I was hoping it would be easier to see from underneath during an oil change.
  18. OC63RAG
    OC63RAG Member
    94
    42
    Quick update on this: I just got underneath the car while the A/C was on and both fans are functioning. I did notice the compressor was warm to the touch. Is this normal? Should it be cold?
  19. BiomedO1
    BiomedO1 Senior Member
    4,363
    2,288
    Left Coast
    Have you tried cleaning out and straightening out the condenser and cooling fins? If the condenser isn't removing the heat from your R134, that will result in less heat rejection - warmer air coming out of your vents.
    When you checked your fans, was it moving a lot of air or just spinning? It needs to move air; to cool your condenser.
  20. pasadena_commut
    2,935
    887
    Southern California
    By "warm" you mean you can put your hand on it and it is above ambient, but well below sizzle and yank your hand back too hot hot? That would probably be normal. Wherever the outlet is will be very hot though normally, because of thermodynamics and the formula PV=NkT which describes the relationship between pressure volume and temperature for a perfect gas. That is, compress a gas and it will heat up. Outlet temperatures should be below 220F or so, but a piece of metal at 220F is in the "burn your finger real quick" range.
    OC63RAG likes this.
