A/C compressor & condenser change DIY?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Cessna157, Jun 16, 2017.
  1. Cessna157
    Cessna157 Junior Member
    25
    Orlando, FL (Walt Disney World)
    Greetings all! I've been following along on the other A/C thread going, but wanted to ask some specific questions.
    2007 Prius with 126,000 miles, living in central Florida where A/C is used 10 months of the year. Noticed 2 months ago it was blowing warm air. Took it to a Toyota dealer for leak check. They did a sniff test but couldn't find anything. Recharged with some dye and sent me on my way.
    Now, 2 months later it was blowing warm again. Took it to an independent shop. They found dye leaks at the compressor and condenser. Said it'd be $2100 to fix.
    I purchased a new compressor kit and condenser for $500. My question is: is changing these 2 parts simple enough for a standard DIY? I don't have a vacuum pump or gauge manifold, but those can be acquired quite easily.
    Looking at Techinfo it seems I might have to drop the front bumper to access the condenser.
    Thanks for any help/tips!
  2. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    Don't be afraid to drop the front bumper. I have our bumper off. The hardest part is where it attaches next to the fender. I pulled out from the bottom (of the bumper) and the sides just popped out of the clips. I got cellophane and a rubber band to cap off the headlamp washer line.
    No experience with AC disassembly/reassembly. But used a manifold gauge I got from Harbor Freight to remove excess freon from our '04 Sienna.
