A/C compressor Manuf. Number
Discussion in 'Prius v Technical Discussion' started by johnpr, Jun 18, 2018.
  1. johnpr
    johnpr Junior Member
    33
    Bratislava
    2012 Prius+ MPV
    Excel
    Hello,
    I need to replace my A/C compressor unit, water has leaked through the connector located on the top of compressor and seems like the water not only damaged the connector (corroded pins), but also made its way into electronics comparent.. one car-electrician tried to bypass the connector by drilling holes into compressor and making new cable trunk.. the compressor wouldnt start, and still gives a faulty code on diagnostic..
    Attached is the photo of my compressor that shows original label.. I want to find a used compressor.. the code is 042200 -0402 , then there is a space, and continues 8P 04075.
    I can find many used units with 04220-0402, but cannot find any with 8P 04075..
    Question for you, is the code important from start to the end of line, or the 8P 04075 is not important?
    Who shall i contact to provide me with the right answer?
  2. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    If I were the one, I'd I won't bother with the other P/N thing, as long as the compressor configuration and connector position is the same.
    Get another compressor from a junkyard, and replace with.
    Ensure you or your AC tech uses the right compressor oil for the job, if not you'd have expensive repairs at the end.
    After replacing the compressor, use a tightening clip to replace the clip on the water hose. It would also be best to replace that hose to a new one, considering aging must have had its toll on the clip and the water hose, or for preventive reasons, you can also envelope a kind of polythene, that's heat resistant on that water hose connections too.
    johnpr likes this.
  3. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Look up Gates PowerGrip hose clamps for another alternative. They are a pain to remove, I’ve found, but do provide a nice even seal. Make sure it is completely over the underlying nipple so it doesn’t constrict unsupported area of the hose if you do go that route. Good idea to replace the hose if you use them too, as they are difficult too remove. (I still don’t know where to get the special tool that they made for removing them without damaging the hose. I also realize it may be hard to position that clamp removal tool depending on hose/fitting location)....
    johnpr likes this.
  4. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    May not be helpful. Sorry!
    #4 jzchen, Jun 18, 2018
    johnpr likes this.
  5. rjparker
    rjparker Tu Humilde Sirviente
    10,938
    6,861
    Texas Hill Country
    I find that a dealer's parts house will usually help you on part numbers even if you don't buy from them. Sometimes you can get a new part online from another dealer for much less as well but have one of the dealers look up the actual part number you need based on your vin. I agree with the compressor oil concern, don't let just anyone change, vacuum and charge the unit. Probably want to buy some oil from Toyota to be sure.
    johnpr likes this.
  6. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    A pair of pinches can be used to grip and remove that clamp.
    johnpr likes this.
  7. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    I think “ES27C” is the part number. Do a Google search and you’ll see what I mean...
    johnpr likes this.
  8. johnpr
    33
    Bratislava
    2012 Prius+ MPV
    Excel
    Hello everybody,
    I finally got a replacement a/c compressor unit from scrapyard for 100euro, and i also bought a brand new connector from toyota dealer for 50euro( crazy money, single pin costs 9euro, and there are 6pins in connector!), to replace the corroded one.
    I have a question, can someone tell me where to find the pin-out diagram for the a/c connector? I am talking about the black signalling cable, that connects on the top of the a/c compressor unit - this cable controls the compressor. There is also orange cable, that powers the compressor, that one is ok.
    Previous mechanic removed the corroded connector when trying to fix my a/c and he doesnt respond to me for some reason.. unable to contact him.. many thanks!
  9. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    johnpr likes this.
  10. johnpr
    33
    Bratislava
    2012 Prius+ MPV
    Excel
    How to connect those pins, from left to right, any idea?
  11. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Okay, I found the wiring for my ‘12 Prius v. I have not figured out the wiring order yet, but as a start, let’s match up the colors:
    G(reen)
    Y(ellow)
    R(ed)
    W(hite)
    V(iolet)
    W-B white with black stripe
    johnpr likes this.
  12. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Do they match up? At least 5 of them I hope, better if all 6....
  13. johnpr
    33
    Bratislava
    2012 Prius+ MPV
    Excel
    I attached two photos of the new connector.. in detailed view, you can see numbers 6-on the left, and number 1-on the right.
    I just need to assign the colours to these numbers - in correct order :)
  14. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Okay, we are almost there. I am still learning how to read the wiring diagram. Can you confirm that I have the correct wire colors while I do this?
  15. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    And this plugs directly into the compressor?
    johnpr likes this.
  16. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Okay. I believe:
    1 G
    2 Y
    3 R
    4 W
    5 W-B
    6 V
    johnpr likes this.
  17. johnpr
    33
    Bratislava
    2012 Prius+ MPV
    Excel
    I dont see the colours, cable is connected right into the inside of the old compressor.. i will only see the cable colours when my mechanic cuts the cables on tuesday.. by that time, i need to know, which colour should go into which pin number..
    Many thanks for your help!
  18. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    The other connector:
    1 O-W
    2 O-B
    O(range)
    W(hite)
    B(lack)
    johnpr likes this.
  19. johnpr
    33
    Bratislava
    2012 Prius+ MPV
    Excel
    Jzchen,
    Dont get me wrong, but.. how much sure are you about the colour-numbering?
    Just if i connect them wrong, i might damage the compressor :):)
    Please can you doublecheck, and confirm?
    Thank you very much!
  20. johnpr
    33
    Bratislava
    2012 Prius+ MPV
    Excel
    B
    By the way, where are you getting this information from, do you have some schematic wiring diagram?
