A/C Compressor not staying on.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by xraydog, May 30, 2023.
  1. xraydog
    xraydog Junior Member
    Arizona
    My Prius A/C compressor is running but it's cycling on and off every two seconds. It's acting like it wants to continue pulling a vacuum but then it stops just before the low side gets to where it should be. I am still getting cool air out of the vents, but it's not where it needs to be.
    I took it to a shop today and they told me they couldn't help any further. But they did pull a vacuum and added the "correct" amount of r134. unfortunately the problem persists. My radiator fans also do not seem to kick into high but im not sure if that's the cause. No other check engine light or DTC code.
  2. JC91006
    16,858
    8,617
    Did you go to a shop that works exclusively with hybrids? The refrigerant in the Prius usages a specific oil, which cannot be contaminated with other oils from other non hybrid cars.
  3. Tombukt2
    Tombukt2 Senior Member
    13,545
    2,440
    Durham NC
    Sounds like there's a blockage somewhere apparently you only have a low side gauge so when you're looking at the gauge and the compressors running it pulls down to where and then they get low gauge starts rising again so what's it pulling down too 40 60 what have you tried unplugging the pressure switch for a minute just to see what happens sounds like there's a restriction in a line maybe on the high side maybe the high side is kicking way up to almost 300 or so tripping hi limit.. the fans are a good place to start.they or it needs be on . Could be trash in line .
  4. Tombukt2
    13,545
    2,440
    Durham NC
    Did they say how low it was just a few ticks or half a can?
  5. xraydog
    Arizona
    Hi everyone. Turns out it was my high side a/c sensor which went bad ant got stuck reading high. Which then caused a loop effect of the compressor turning on and then off repeatedly. I verified by bridging the connectors on the sensor plug, then everything worked normally.
  6. Tombukt2
    13,545
    2,440
    Durham NC
    That'll do it
