A/C doesnt work, makes constant hum, warm air works, recently replaced 12v
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Howard c, Jul 25, 2017.
  1. Howard c
    Howard c Junior Member
    17
    vancouver
    i recently replaced my 12v battery about 2 months ago, dont think i used the A/C until today and realize that it doesn't work. it also makes a constant hum sound. the heat works still, and fan works still.
    any idea what might be causing this? related to 12v?
    1SteelerFan likes this.
  2. Mendel Leisk
    38,658
    Not sure. Kinda suspect the 12 volt change isn't related. You could raise the hood, listen if you can hear the compressor, locate and look at the sight glass. The latter's a little window on one of the refrigerant lines. If the charge is ok you should just see an occasional bubble whiz by while the compressor's running, and a swirl of bubbles when it stops.
  3. Howard c
    17
    vancouver
    thanks, so i brought the car to service @ toyota, they charged $130 just to look at it! o well, so they say the A/C condenser is leaking and they have to replace the A/C condensor and recharge system which is quoted to be $780 with labor included.
    is this reasonable or is this something I should shop around other bodyshops and ask? It looks like i can buy a new A/C condenser on ebay for $~80 , possible to buy myself and ask a shop to replace it?
    any advice would be appreciated.
  4. Howard c
    17
    vancouver
    what exactly is a "recharge system"?
  5. 1SteelerFan
    1SteelerFan Junior Member
    Tampa
    Probably needs a a/c charge. I have a 2005 Prius I put envirosafe refrigerant in it , and I get 40 degrees coming out of the vent. It's been in the 90's here in Fl
  6. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    Take to an actual refrigeration shop, (an A/C shop). You'll probably get a price close to 1/2 that amount.
