A/C & heater with EV charge?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Au-Toe, Apr 30, 2014.
  1. Au-Toe
    Au-Toe Matrixowner
    86
    Chino, CA
    2014 Prius Plug-in
    I tried skimming through topics and even scrolled real quick through the FAQ thread.
    Does the A/C and heater run only with Ice? Or is it able to run on EV alone?
    Or does A/C run on ice only and heater able to run on EV? (Or vice versa)
    It's been getting hot here in SoCal. And was wondering this question.
    I hope I worded that correctly as gas as my question. I hope you get what I'm saying.
    iPhone ?
    52,759
    a/c runs on battery and heat comes from ice, except seats and mirrors are electric.(y)
    xpcman likes this.
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    And we can close this thread. :)
  4. retired4999
    2,652
    627
    Eau Claire, Wi.
    (y)
  5. GregP507
    GregP507 Senior Member
    3,002
    481
    Heat comes from the ICE, but the good news is that it only takes 3-4 minutes, because the coolant lines run through the exhaust system. We're hoping that Toyota adopts an electric interior heater that works when the PIP is plugged in.
  6. bisco
    52,759
  7. bisco
    52,759
    :p
  8. CharlesH
    2,798
    1,166
    Roseville, CA
    More specifically, the A/C runs on the big traction battery, not the little 12V battery.
  9. bisco
    52,759
    and thank you, otherwise, we'd be a sweaty mess.:)
  10. bisco
    52,759
  11. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Keep in mind that once the coolant is warmed by the engine, it will provide heat for several minutes while the engine is off. So, it will cycle on & off as you drive, allowing EV driving in between without the cabin getting cold.
    usbseawolf2000 likes this.
  12. bisco
    52,759
  13. Mendel Leisk
    42,248
    Wait a sec: heat comes from ice???
    Sorry, having an anti-acronym morning...
