A/C into the glove box?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Fubar1764, Oct 25, 2012.
  1. Fubar1764
    Fubar1764 Member
    127
    Houston, TX
    In the interest of having a small cooler in the car, has anyone diverted a/c air into the glovebox? I'm thinking diverting into the upper glovebox might be reasonably easy. Anyone who's torn apart the dash have any thoughts?
  2. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    i don't think it will cool much and the texas sun hitting that black glove box lid will warm it right back up. you could just bring a small igloo...
  3. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
  4. 69shovlhed
    2,170
    752
    Delaware
    thats cool but its not worth buying a dodge over...
    WE0H likes this.
  5. Fubar1764
    Fubar1764 Member
    127
    Houston, TX
    A lot of manufacturers have done it since it was introduced in the late 90s. Just wondering if anyone might have suggestions on how to do it with the Prius.
  6. WE0H
    WE0H Senior Member
    3,247
    528
    Do some experimenting with thermoelectric coolers and see if you can come up with something with enough cooling capacity.
    Mike
    Mobile on my SGH-i717
  7. Fubar1764
    Fubar1764 Member
    127
    Houston, TX
    The idea came to me because I used to rest a sealed drink in front of the a/c vents of my SC400. After about 30min, the drink would be cold. :) I think diverting half of the capacity of one of the front vents would be more than enough to turn the glovebox into an icebox.
  8. WE0H
    WE0H Senior Member
    3,247
    528
    Try it ;) If it isn't quite enough cooling capacity you could take some Thinsulate material and insulate the glovebox.
    Mike
  9. Fubar1764
    Fubar1764 Member
    127
    Houston, TX
    Hoping someone who has taken apart the dashboard may have some insight as to the feasibility.
  10. Daves09prius
    Daves09prius Active Member
    680
    161
    Gettysburg, PA
    The filter for the A/C is behind the lower glove box, you could somehow possibly take air from there?
  11. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    That's the intake filter, not the exhaust. You'd be getting air at ambient temperature.
    The glove box fits quite tightly in the dash with all the HVAC ducting and what not... I'd first figure out how to insulate the box before venting it. After all, what's the use in cooling the box if it can't maintain its temperature?
  12. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    Maybe easier to fashion a box at the passenger side foot well that takes the cold air from the existing foot vent.
  13. Britprius
    Britprius Senior Member
    5,194
    1,924
    Herefordshire England
    The easy way to make a cool box in the Prius is to use the center armrest box as there are air ducts under the seats for the rear of the car. It would be simple to pipe the duct into the side of the box witch also would be easy to insulate and partition for a smaller area if required. Doing this could also double up as a warm box to keep the takeaway warm if the heater was turned on.
