A/C is intermittent warm and cool, not COLD
Discussion in 'Gen 2 Prius Technical Discussion' started by PapaWill, Jun 4, 2020.
  1. PapaWill
    PapaWill Member
    137
    25
    Maui, Hawaii
    07 with an intermittent A/C issue... the system was just recovered and a pund of 134a was replaced in the system ( along with dye). It shows NO LEAKS (so far) and the temperature is cool, not COLD ( around 60 degrees at most. This is not enough to keep me cool and I am not sure what is going on. The condensor is working as I see that temp change as I test along the flow of the system. The compressor is on and obviously doing SOMETHING... How do I test with the given situation? The compressor sounds normal. Or is this just a compressor that is on its last legs? Any air conditioning experts in the house?
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
  3. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Are the condensor fans working and/or does it get colder while being driven?
  4. lech auto air conditionin
    830
    606
    261
    san francisco
    What is this recovery performed on a large RRR What is this recovery performed on a large RRR (recovery recycle recharge) Machine?. 1 pound 454 g what does the sticker under your hood say for its requirements of refrigerant ?. Or did this one town come from a 1 pound can ?. Because the cans for R134a or actually only 12oz, 340g,
    If the refrigerator was recovered that means it was hooked up to a machine and it had gauges on it that means you could give us the pressure readings.
  5. spdracrm3
    spdracrm3 Member
    58
    47
    estacada or
    When was cabin filter last changed?
    SM-G960U ?
    SFO likes this.
  6. PapaWill
    PapaWill Member
    137
    25
    Maui, Hawaii
    Thank you for your input on the '07... All the work was done by a shop who used a recovery/recharge machine and what they told m is that 1 lb of refrigerant was added.. What I did not tell you was that this car has been for sale for a couple of weeks and As of a couple of hours ago I sold it to a young couple who were not very concerned about the A/C... I told them everything about it and they said they prefer to not use A/C and just power the windows down. So this car is already history.
    BUT I have another '07 that someone gave to me. I replaced the actuator and installed a traction battery out of a gen 3 and guess what needs to be repaired? YUP, you guessed it, the A/C is not working. Does it have a leak? Since there was NO refrigerant in the system, I would say yes. All I did with this so far (and this was a couple of weeks ago so I am a bit fuzzy on the exact details) was hook up a pressure manifold and vaccum and added some dye and 1 can of refrigerant 12OZ... No PAG oil. Since that time, I see no obvious leak, but I have not driven the car very much since this aformentioned event. I do see some very small speck of dye on the compressor hose fitting that would be on the high pressure side, but nothing more. I did not record any pressures on the high and low side. Suggestions at this point? And thank YOU!
    PS I have looked at lech auto A/C videos but nothing seems to hit on the issue yet...
