A/C issue
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bentg, May 7, 2019.
  1. Bentg
    Bentg Member
    36
    49
    New Prague, Minnesota
    Hi.
    2010 Prius owner here -- this car is new to me (previously driving a 2013 Prius C), and I'm having some trouble figuring out the A/C. Doesn't seem to want to turn on. Can anyone tell what I'm doing wrong? Hoping it's user-error. Video below.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    Does the AC work but the light is burned out?
    Any dash lights on?
  3. Bentg
    Bentg Member
    36
    49
    Doesn't seem to be any dash lights on. A/C doesn't seem to turn on either way.
  4. orenji
    orenji Senior Member
    5,887
    3,488
    Well you pushed everything! Looks like the switch is bad or the light is burnt out. You don’t feel cold air when you push the front window defrost?
    Raytheeagle likes this.
  5. Raytheeagle
    11,267
    15,525
    2019 Prius Prime
    Any damage in the cars history?
    Do you see any movement in the sight glass?
    Pluggo likes this.
  6. orenji
    5,887
    3,488
    Try holding the A/C button down. Don’t just tap it.
  7. Bentg
    Bentg Member
    36
    49
    Unsure what the sight glass is.
  8. Bentg
    Bentg Member
    36
    49
    I did try this. Didn't work.
  9. orenji
    5,887
    3,488
    Well this is a first. The A/C’s are pretty well built. So it could be a loose wire or bad switch.
  10. Raytheeagle
    11,267
    15,525
    2019 Prius Prime
    Under the hood just behind the passengers side headlight there is a small sight glass on the ac line that you can see.
    See if there is any movement you can see when the car is on and the ac should be running.
    orenji likes this.
  11. Bentg
    Bentg Member
    36
    49
    No movement that I can see. When I hit the A/C button, there seems to be no change in the car whatsoever.
  12. ChapmanF
    18,861
    Put the car in ACCessory mode (starting with the car OFF, one push of the power button without pressing the brake). Then after 5 seconds or so:
    Hold the AUTO and the FRESH/RECIRCULATE buttons on the A/C control panel at the same time, keep holding them down while you push the power button one more time (no foot on brake), turning the car from ACC to ON. Keep holding AUTO and FRESH/RECIRCULATE until you see the control panel lights start to blink.
    All of the lights on that panel should blink together four times, so you will see whether the light in the A/C button works or not. You should also then see one or more two-digit codes cycling through at the left side of the LCD panel. Those might give you more info about any problem. (If the only code is 00, then it isn't reporting a problem.)
    If the light works, and no problem is reported by code, I might start by assuming just a dirty contact under the A/C button, and see if I could clean that up before guessing anything more involved.
    I'm assuming the A/C really isn't turning on. You can pretty much hear it if it's running, especially if the hood is open. Sounds a little bit like a Cessna off in the distance.
    Pluggo, orenji, CR94 and 1 other person like this.
  13. Bentg
    Bentg Member
    36
    49
    Yeah, I could always feel/hear a change in my C when I'd turn the A/C on, so this feels different. I'll try your steps and report back. Thanks!
  14. Bentg
    Bentg Member
    36
    49
    Here's what I got. A/C button lights up and double zeros.
  15. ChapmanF
    18,861
    Was the car ever owned by a smoker?
    A friend of mine bought a used laptop on ebay and the keyboard was about useless. Sme letters wuldn't wrk at all, ttttttthers wuld reppppeatttttttt like ttttttttthere was n tttttttttmrrw.
    We took the keyboard out of the laptop and dumped it in a casserole dish with enough distilled water to cover it, and swished it around, occasionally pouring out the gray water and adding some new. Then it needed a couple days to dry out. Worked great after that.
    It might not be my first thing to try on the A/C button. That control panel comes out of the car really easily, but I've never explored how to disassemble the panel itself. It can surely be done, because there are folks here who change the LED colors for fun. Probably you'll find a rubbery sheet with 'bubble' spots that act as the springy elements behind the buttons, and the sheet will be over metallic contact areas on a circuit board. A cotton swab and some contact cleaner across the contacts beneath the A/C button might do the trick.
  16. Bentg
    Bentg Member
    36
    49
    I just picked it up a couple weeks ago, and yes, I suspect it was smoked in. I’ll try taking it back in to the dealer and see if they’ll take care of it. If not, I’ll give it a whirl myself.
