A/C Mode Keeps Changing By Itself.....help!
Discussion in 'Gen 3 Prius Technical Discussion' started by Prius Five Guy, Sep 7, 2012.
  1. Prius Five Guy
    170
    Los Angeles
    2013 Prius Plug-in
    Prius Five 2012 fully loaded in Blizzard Pearl.
    Issue: A/C keep changing mode from face/head only to feet every 2-3 minutes on its own.
    *Auto button light is off and this continues.....
    Any suggestions/instructions on how to resolve this problem? I've stumped all the dealers, no one has a fix.
  2. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    This is why we recommend using "auto". Otherwise it will drive you crazy arguing with it.
  3. Chunker
    Chunker My name is Chunker...I wear a hat
    71
    I don't have that problem when I tell it to do face/feet or face only. I'd take it back to the dealer and have them fix/take a look at it.
  4. sLick415
    sLick415 Member
    214
    55
    San Francisco, CA
    If by "on its own" you mean when you open and close your vents, then yeah it's normal. That's the only time it changes for me.
  5. 50324prius
    50324prius Junior Member
    39
    iowa
    Could the temperature have been set at a point that would have caused this? Mine will do that if I set the temp. to about what outside air temp. is. The inside gets cool enough quickly and then it thinks it needs to warm the inside air and it cycles like that.
  6. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    If its not set to auto then the settings "should" stay where u put them at. If they are changing, take it back to the service department. Why mess with it when its still covered under warranty.
  7. Former Member 68813
    3,524
    983
    US
    I vaguely remember setting changing by themselves when the car was new. I don't see it now. Not sure what was different then. Try different settings and report back.
  8. Prius Five Guy
    170
    Los Angeles
    2013 Prius Plug-in
    Was actually a simple fix. I was hitting the wrong "mode" button (head to foot) which seems to have activated the automatic changes.
    Auto light is off and since finding the correct mode change button to press...issue is solved.
    Thanks for all your input guys!
  9. bisco
    52,773
  10. 50324prius
    39
    iowa
    That's the nice thing about owning a Prius.... you never stop learning what it will do. And I mean that in a good way!
  11. Chunker
    71
    Ahh...you were probably hitting the cabin filter button...=)
  12. Former Member 68813
    3,524
    983
    US
    Yes, that was it. I forgot the details as it was 2 years ago. Since that I learned not to use it. I prefer manual mode and fresh air. It's annoying enough to have to switch to fresh air every time AC button is pressed.
