A/C not getting cold
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Vtoribio510, Jul 31, 2013.
  1. Vtoribio510
    Vtoribio510 New Member
    Why when I am in hot weather it takes a long time for the a/c to start cooling off the car
  2. MPGnutcase
    MPGnutcase Active Member
    579
    114
    Chicago
    check your cabin filter first
  3. Drdiesel
    Drdiesel Active Member
    585
    152
    Monterey CA
    Because it needs to drop the temperature of the vehicles interior too. What color is your car ? What is the outside temperature ?
  4. Vtoribio510
    My car is the dark blue with the moonroof and solar panel it was probably 95
  5. MPGnutcase
    579
    114
    Chicago
  6. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    Make sure it in in rec mode not outside air. Also turning off eco mode lets the ac run at full power. If it doesn't feel cold then your going to have it looked at. It may take a couple of miles to cool the car down to a nice level.
  7. lech auto air conditionin
    830
    601
    260
    san francisco
    Good question DrDiesel.
    Dark blue, that's a hot color, strike one. 95F strike two. Moon roof strike three. You roll your windows up all the way and park in the sun, YOUR OUT!. (n)
    It will take some time to cool that down all that hot interior mass. If it's 95F out side and 120+F inside your car DO NOT RUN YOUR A/C ON RECYCLE!. It is easier to to cool 95F air then 120+F air hands down. Then after the interior cools below outside temp then you can use recycle air.
    This is a 2013 car I don't think you need to check your cabin air filter yet. Unless you have been Baja desert dusty off road dirt racing or parked every day under trees that drop lots of leaves and pollen.
    Question ? is this your first car, first car with a/c or you are comparing a non hybrid car with a hybrid cars a/c ?.
  8. Drdiesel
    585
    152
    Monterey CA
    Did you open the windows for a few minuets to exhaust the hot interior temperature. Blue will
    hold heat more than a lighter color. Was the sun-roof shade open during the day ? Direct sunlight
    through the sun-roof will create higher interior temperatures. I always open the windows to
    exhaust the hot interior and run the A/C around 70° to 75° in ECO Mode with the recirc mode active.
    Get a thermometer at the local parts store and stick it in the center vent. This will give you accurate
    temperature information.
  9. rdgrimes
    rdgrimes Senior Member
    1,740
    444
    New Mexico, USA
    2018 Prius Prime
    There was a recent study done on car skin colors and heat. They found that it made no difference what color it is, the skin reached the same temperature regardless. Dark colors might get warm faster, but they all reached the same temp in a matter of minutes, and it made no difference to the inside-the-car temps. Might have been Consumer Reports that did the study, can't remember for sure.
  10. lech auto air conditionin
    830
    601
    260
    san francisco
    sounds like consumers reports, not always right. Black is always hotter then white , 5th grade science experiments remember so basic . Any painter with any practical experience knows this or will discover it the hard way if they don,t know. If you remember the old days of black vinyl seats and jumping in with shorts on and burning the backs of your legs, compare to the same car with white seats was bearable.
    And yes driving the first two blocks or so is best with windows down will help. But if you just want fast comfort and not one of the MPG freaks ( sorry but true) enjoy your comfort, crank up the A/C all the way no ECO SB and run that baby full blast. ENJOY YOUR A/C
    I own a Prius C and the A/C is on all the time. After I added 3M crystalline window tint on all windows that really helped. It blocks both UV and IR. It dose not have to be dark to block IR. IR wavelength is what strikes a object and produces heat. This is all basic HVAC and energy management class 101. Putting the lightest shade window tint on that large front window is #1 no one will ever know its so light.
    MPGnutcase likes this.
  11. Bill Norton
    Bill Norton Senior Member
    1,823
    598
    MONW, Ks.
    rdg,
    This report is Boe Gus. Go up to any white car in a parking lot and put your forearm on it.
    Now go to a black car. Have a burn kit ready;). Coming from two black cars to a white Gen3 with the solar
    sunroof is like night and day.
    lech,
    I agree with the 3M crystalline. It is a new amazing technology!! The stock glass does have decent IR rejection but this film makes it even better.
    However you got it wrong about a Gen3 sunroof. That is a PLUS. It is a Solar Sunroof, it runs the interior fan whenever it is in the sun and it is hot out. I don't have data, but when I open my car door after sitting in the sun all day and I'm greeted with the fan blowing fresh outside air in my face until I power up the car.
    A sun shade for the big front window helps too.
    Does ECO mode do anything to the AC?
  12. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    its the interior color the is most influential.
  13. lech auto air conditionin
    830
    601
    260
    san francisco
    sorry, i thought it was just a normal sun roof. :oops: Oops!
    As for ECO , Here in San Francisco city with all these hills driving I get better GPM with it off, both me and my wife. I'm a hard driver and she's a soft driver. Both of us get 44 to 46. We can bump it +2 MPG if we try real hard to drive like one the those ECO MPG :whistle::whistle::whistle: Wack Jobs in a Prius doing 65 in the fast lane when every one else is going 75+.:mad: :mad:
  14. Bill Norton
    1,823
    598
    MONW, Ks.
    lech,
    I was asking if the ECO switch does anything with the HVAC system. I don't think it does on this car.
    It seems a lot of people think that the ECO and PWR buttons have ANY influence on fuel economy.
    They don't. They only change the way the engine responds to a pedal travel, the response curves are different.
    Full Throttle Pedal = Full Engine Power,,, no matter what you do with those silly switches.
    (One guy said he looks down and presses PWR before doing a lane change! Distracting and useless.)
    Only your right foot controls power and fuel economy.
    ftl likes this.
  15. 32kcolors
    32kcolors Senior Member
    5,683
    952
    124
    Redondo Beach, CA
    Someone ought to do some real world testing on a black Prius with Misty Gray interior vs. a Blizzard Pearl Persona with the black interior.
  16. tach18k
    tach18k Member
    406
    38
    SoCal Beach Area
    Well lets try this first, if you jump in the car and go to AC, the interior ducts need to cool off first, so for the first bit the ducts will be hot, then they will cool off. If your driving and into the sun, the front of the car seating will remain hot just the sun passing thru will keep thing toasty, when you change direction and the sun to your side or rear, it will cool off or seem like it as the sun is not shining on your chest. Blowing the air at your face and body will only just slow the process down. circulate the air betters the cool down affect.
  17. Wayward
    Wayward Member
    145
    26
    Idaho
    I only drive in ECO but supposedly ECO drops the AC down to like half to get the best mpg, you have to turn off ECO to get full AC.
    At least that's what it says in the manual and what I have read here.
  18. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    Bill, I agree about throttle mapping, but if ECO reduces AC compressor usage, it would have to effect fuel economy.
  19. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    With gauges, yes.
    We have an 11 Rolla (red) with a black interior and I have the charcoal gray in the Prius. Hands down the Rolla gets much hotter much faster. Of course I suppose once the temps are in the triple digits, it probably really doesn't matter much...
  20. Bill Norton
    1,823
    598
    MONW, Ks.
    Oh yeah with proper instrumentation.
    I'll have to find it, but there is a spec sheet on Gen3 glass IR ratings. Search it.
    The Gen 3 has an amazing ~55% Heat blockage, I think, IR, and all the others have a good rating.
    But I'm with you on interior color. That's why I have that light colored leather in my Gen3.
    And with the Solar Roof it is like not other car!!! I still use a cheap fabric hoop sun shade in the front.
