a/c not working, but no a/c codes
Discussion in 'Gen 3 Prius Technical Discussion' started by greasemonkey007, Sep 3, 2016.
  1. greasemonkey007
    greasemonkey007 Active Member
    287
    106
    South Central Arkansas
    I took a look at a 2010 that has been wrecked on the front. It got a new used radiator support, condensor, radiator, etc. He said it worked for about 5 months and has quit working. He put a used compressor on it and charged it up. No luck. Then he changed the amplifier. Still no luck. When I put the laptop on it with techstream, it had no a/c codes. It did have some airbag codes due to him not replacing the airbag when he fixed the car up.
    Going to the live data, I saw the target compressor speed was 0. I went to active test to try to turn the compressor on with no luck. While in active test, I was completely locked out of all fan and a/c related buttons. I couldn't turn anything up, down, or off with the controls. Once I canceled the active test, everything worked normally. I tried clearing codes and refreshing health check 3 different times but all the results were the same. No a/c codes. All lights on the buttons turned off and on normally unless I was in active test.
    Any ideas?
  2. StarCaller
    StarCaller Senior Member
    1,283
    732
    Cedar Crest, NM, USA
    no, seriously, no idea/ :(
  3. AzWxGuy
    AzWxGuy Weather Guy
    1,077
    554
    Tucson, AZ
    2021 Prius
    Maybe you could get a better response from the Gen II thread. Considering the damage to the vehicle, I would suspect there is still a leak somewhere and system pressure is too low to start. Did the mechanic do a draw-down test for leaks? I don't know enough about Techstream to say whether it can disable the low pressure lockout.
  4. greasemonkey007
    287
    106
    He said he pulled a vacuum and it held, so I didn't put the gauges on it.
