A/C oil replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MR.K, Jul 10, 2008.
  1. maximusdec
    maximusdec Member
    108
    Was flushed at a local shop. I was suppose to change the expansion valve but it was just too much work.
    Regarding the oil capacity, the service manual says if replacing the condenser with new to add 1.4 oz.
    For the compressor it says the capacity is 3.52 oz + 0.53 oz. Why the plus, am not sure. So I added somewhere on the middle
  2. lech auto air conditionin
    830
    606
    261
    san francisco
    Don’t worry at least you’re not under because there’s plenty up in the evaporator
    maximusdec likes this.
  3. Pedrocaxias
    Pedrocaxias New Member
    Richmond
    Hi guys, but where in the compressor do you put the oil compressor? By the discharge hose or suction hose hole at the compressor ?
  4. Pedrocaxias
    Richmond
    Where exactly did you insert the ac compressor and do you have the link where did you buy? Thank you
  5. Banksy
    Banksy Active Member
    415
    133
    Lancaster Pennsylvania
    Ebay used was like 35 bucks
    I mean as for inserting it...
    It's on the passenger side near the bottom of the engine
    You'll need to remove the plastic shielding underneath
    Real pain to get in there
    Put the car on jack stands of possible and get as much room as you can to work
    Pretty straightforward taking it off
    But getting it off is the hard part.
    Pedrocaxias likes this.
  6. maximusdec
    maximusdec Member
    108
    Bought it from a local salvage yard for $75. The oil is inserted directly into the bigger hole on the compressor before installing
    PaulDH and Fostel like this.
  7. Classic Car Guy
    Classic Car Guy Active Member
    506
    136
    Northwest, USA
    My car has 176k miles and the AC works just fine. I was wondering if it calls for changing the compressor oil? Anyone have a picture or video guidelines how to do it?
    Thanks,
  8. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,015
    NJ-USA
    If the A/C system works normally, just leave it alone.
    About the only periodic maintenance would be to check & replace the cabin air filter as needed. Maybe check the front of the condenser & radiator for leaf debris (or fin deterioration).
