A/C refrigerant refill question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cooldyood, May 23, 2021.
  1. cooldyood
    cooldyood Junior Member
    45
    Wash DC
    Hello,
    My 2006 Prius with 240k miles has been making a loud grinding noise when a/c is turned on. Having read these forums, my understanding is that the refrigerant needs to be refilled (this hasn't been done in all these years). Is this as simple as getting the refrigerant topped off, or do I also need a/c flush fluid and/or a/c compressor oil?
    Refrigerant: Certified AC Pro Auto Air Conditioner R-134a Refrigerant, 12 oz, 301CA - Walmart.com - Walmart.com
    A/c flush fluid:
    A/c compressor oil:
    Thanks so much.
  2. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
  3. Mendel Leisk
    42,271
    Consider AC service at dealership? That was around $150 in my experience. Of course if it’s something like a shot compressor that number’s out the window.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Loud grinding noise is not good.
    Have someone turn on the ac to max while your under the front of the car by the front passenger side tire that's where the compressor is. See if its making the noise if so that's really bad as the g2 compressor is very expensive and if it is grenading itself it will contaminate the entire loop.
    My bought new 07 is at the Ac shop right now getting the evap coil under the dash replaced as it had a very slow leak. Horrible job.
    $1100. Waiting to get it back.
    #4 edthefox5, May 23, 2021
    Samuel Williams Jr likes this.
  5. lech auto air conditionin
    830
    606
    261
    san francisco
    Grinding noise is usually a really bad deal.
    I have a few videos possibly two or three on Prius chat different noises that Prius compressors make when they’re bad or going bad and need to be replaced.
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    I don't think that you read here, or anywhere else for that matter, that a loud grinding noise means you are just low on refrigerant.
    I also think that any attempt at a DIY fix on your part is NOT a good idea.
    You need a professional diagnosis.
  7. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Picked up my 07 today and they did a good job ac is wicked cold again. I stopped by early thought it would be done and they had the dash pulled to the firewall horrifying sight lol just a sea of wires and plugs.
    $1085 out the door plus I tipped the poor bastard who did the work. Great job.
    Thanks to Lech i got my butt in gear and got it in before the compressor blew up.
    ICE COLD AIR
    Gulf to Bay Blvd
    Clearwater Fla
  8. yossi
    yossi Junior Member
    61
    If my compressor is not making any bad noises and the air is cool, but not cold, is that just low refrigerant or could be be the compressor? the compressor is definitely working because the air is at a lower temp than the inside or outside, but its definitely not "cold" and the car is not coming down to a comfortable temp
  9. Mendel Leisk
    42,271
    More’n likely. That was my scenario, and a regular dealership AC service got the chill back. :)
  10. edthefox5
    10,096
    4,837
    Clearwater, Florida
    If air is cool not cold you have a leak. Just like mine. Low refrigerant. Using it while low on ac is really hard on the compressor and could damage it.
    Stop using it till the leak is fixed. If you damage the compressor that’s really expensive.
    If you look at the sight glass while car in ready ac on max you will see really fast flow that’s basicly micro bubbles. Not good.
    They will charge it up with dye and find the leak. Hopefully it’s in the engine bay and not the evap coil under the dash like mine.
    The g2 ac system is excellent it should have freezing cold ac.
  11. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    Could we stop with all the doom and gloom. Geez. @yossi 's car is 13 years old, just like yours is 14 years old. AC systems leak from the time they're installed and charged. No seal around any moving part is perfect. Unless there has been a catastrophic failure, every AC system in every car is going to degrade over time. Catastrophic failure = rapid degradation, not over a period of years. This does not mean it has a leak that is considered a system failure, so quit trying convince everyone the only solution is to stop using the AC and immediately go to the nearest AC repair shop. That's a load of crap. If you choose to spend a thousand dollars, that's fine and more power to you. That is not the solution for everyone.
    Based on the minimum symptoms he listed, making any kind of diagnosis about his AC system is just guessing.
  12. Samuel Williams Jr
    246
    Dayton NV
    If the air is just cool but not cold?
    I would stop using the A/C and have the system checked out. If it "has," leaked R 134 it has also leaked the oil for the compressor. The old R12 systems leaked R 12 thru the hoses all the time and that is why they needed to be recharged on a much more frequency basis and why the R12 was ditched in favor of R 134. And as a point of reference sigh, our Gen 2, is a 2005 and the AC still blows ice cold. :)
    edthefox5 likes this.
  13. lech auto air conditionin
    830
    606
    261
    san francisco
    1: if you take your car out of the sun like parking it in the garage early in the morning when it’s a little cooler.
    1a: Place your fan on minimum speed
    1b: make sure you’re in recycle Mode
    1c: Does the temperature out of your Dash come out much colder now when you perform the above procedures.
    If so most likely you’re just low on charge
    2: now move the car back outside in the sun when it’s about 10° warmer a little later in the day
    2a: put your fan on high speed and your mode setting on fresh air
    2b: Is the air temperature out of your dash much warmer ?
    If it is the odds are you’re just low on refrigerant
    3: also when it is warmer outside you no longer see water dripping out of your drip tube underneath the car from the condensation coming from the evaporator ?
    3a: do you remember when your air conditioning performed well (cold) seeing the water dripping out from underneath your car
    3b: And if you live in the part of the country where the outside humidity is usually 50% or above on a good working air conditioning system when it’s been ran in Max cooling for about 10 or 15 minutes you will usually see condensation water developing on the large suction line air conditioning metal pipe returning back to the compressor.
    This is usually an indicator but not always under a high load condition in warmer weather you still have enough refrigerant that some of the refrigerant is still left over for a lower superheat meaning that there is ample refrigerant also cooling off your compressor and returning lubricant to your compressor on a well running AC system.
    4: usually when the refrigerant is low and you just have a little cooling coming out of the dash and you grab the large suction line coming out of the evaporator and it’s only a little cool but not cold that means the compressor is starving for refrigerant and the superheat is high and there’s a lack of refrigerant cooling going on to cool the electrical windings of the motor.
  14. sam spade 2
    7,035
    2,804
    2017 Prius c
    Of course it is.
    But "doom and gloom" guesses are just as valid as those seen through rose colored glasses.
    Especially if they come from someone who had YEARS of experience with AC systems.......or is based on a report like
    " making a terrible grinding noise".
    GEEZ yourself.
  15. Samuel Williams Jr
    246
    Dayton NV
    Well I can't think of a single instance where hearing a "grinding sound," coming from a car is good news? But perhaps I lack imagination?
  16. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    Sam, perhaps I should have been more specific as to the post I was responding to? If you read my post, and think for a second, perhaps you'll be amazed at how it coordinates with the post directly above it. Read the first couple sentences and put 2 and 2 together. @yossi had no grinding noise. Work on reading and staying in the timeline. Damn you are difficult.
    #16 TMR-JWAP, May 26, 2021
  17. sam spade 2
    7,035
    2,804
    2017 Prius c
    Yes, a quote would have prevented my reply altogether.
    I AM difficult....but I try to limit that to those times when it is deserved.
    I am not always successful in that. :whistle:
  18. KellyKellz
    KellyKellz New Member
    Thank you!! Very helpful! This is my problem so I will buy R-134A refrigerant. Is there a specific brand I should get? I noticed that not all of them are treated equally therefore not all are good for any hybrid/electric cars. It usually says so in the description. This is the one I'm considering. Is that one good to use??
