A/C works only when cooling??
Discussion in 'Gen 2 Prius Technical Discussion' started by daveleeprius, Jan 29, 2007.
  1. John in LB
    John in LB Life is good
    399
    27
    Orange County
    <div class='quotetop'>QUOTE(usbseawolf2000 @ Jan 31 2007, 01:11 PM) [snapback]383490[/snapback]</div>
    Freon is a trade name for a group of chlorofluorocarbons used primarily as a refrigerant. The word Freon is a registered trademark belonging to DuPont.
    To be correct: It was not just Denso. This substance was banned by the Montreal Protocol on Substances That Deplete the Ozone Layer. The treaty was opened for signature on September 16, 1987 and entered into force on January 1, 1989.
    I am not trying to be anal here, just wanted to make sure that Toyota or Denso don't get credit for this - they were definitely not first on board with this issue (Toyota was one of the worst polluters in the world in the 60's, 70's and even 80's...)
  2. PA
    PA Member
    427
    27
    Raleigh, NC
    2019 Prius
    I know this has nothing to do with the discussion, but what the heck.
    John in LB, that really is a nice avatar, beatiful colors. I like the reflection of the palms on the car. Great photo!
  3. John in LB
    399
    27
    Orange County
    <div class='quotetop'>QUOTE(PA @ Feb 1 2007, 10:33 AM) [snapback]383992[/snapback]</div>
    Thanks, but I got it from somewhere on around here, when I registered. It looks close to where I live and the color of my car - so I picked it. Sorry, I can't take credit for taking the photo myself.
  4. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    The Toyota A/C compressor is electric, run off the NiMH battery pack through the inverter/converter. It's variable speed, and if you have the hood/bonnet open with it on, you can quite clearly hear the pitch change as it adjusts to cooling demand.
    That said, most automotive A/C systems have thermisters and/or high/low lockout to protect the A/C compressor from abnormal pressure/temperature. Once you get much below about +65 F, "superheat" is almost impossible to achieve anyway.
    Ever catch a "technician" attempting to charge a home A/C on a day colder than about +80 F? Well, he's an idiot, because he will never get the correct charge.
    http://www.udarrell.com/air-conditioning-efficiency.html
    I know with the industrial units I'm familiar with, the control network will "lockout" compressor function if the ambient temp is lower than +55 F, which is considered the lower safety limit for effective compressor lubrication. Let's not forget the compressor oil will settle out if the entire system is much colder than around +55 F. The only exception is if a heater blanket is put on the compressor to keep it warm in lower temps.
    Toyota uses the "technically correct" definition of "air conditioning" which is to maintain the correct temperature and humidity within a certain space. This is done by applying heating or cooling as needed, within the safe operating limits of the equipment.
  5. cireecnop1
    cireecnop1 New Member
    338
    Pueblo, CO
    I love the electric cooling on this thing!!! Now I only with that I would have ordered this thing with remote start for those 100+ days. oh well, just a side note TOYOTA ROCKS!!! for anyone who didn't already know. B)
  6. genalex
    genalex Member
    265
    Jersey suburbs of Phila.
  7. jayman
    13,439
    641
    Winnipeg Manitoba
    The Prius does use flex lines to the A/C condenser, so yes there will be o-rings. Could be a lot worse, Ford's A/C systems are assembled with quick-lock fittings, and they naturally lose tension and fail over a period of 5-6 years.
  8. genalex
    genalex Member
    265
    <div class='quotetop'>QUOTE(jayman @ Feb 13 2007, 09:23 PM) [snapback]389910[/snapback]</div>
    OK, not so bad. It's the shaft seal on the belt driven compressors that I worried about. That damned thing will eventually wear-out if you keep the car long enough.
    BTW, are there any belts in the Prius?
  9. KTPhil
    KTPhil Active Member
    1,379
    22
    Yup, for the water pump.
  10. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    <div class='quotetop'>QUOTE(genalex @ Feb 13 2007, 07:38 PM) [snapback]389970[/snapback]</div>
    Not for the AC Compressor.
    Here is a schematic of the compressor assembly.
  11. genalex
    genalex Member
    265
    <div class='quotetop'>QUOTE(seasalsa @ Feb 13 2007, 11:37 PM) [snapback]390003[/snapback]</div>
    Yup. That's the classic "sealed unit" compressor design that dates back to early home fridges.
    <div class='quotetop'>QUOTE(KTPhil @ Feb 13 2007, 11:36 PM) [snapback]390001[/snapback]</div>
    Hmmm. They must have a reason for strapping that to the engine shaft, when an electric motor driven pump would seem so easy and could help sustain cabin heat during ICE-off periods.
  12. KMO
    KMO Senior Member
    2,029
    751
    Finland
    2023 Prius Prime
    It has an electric water pump too, for when the engine's not running. Not quite sure why they decided to have both.
  13. seasalsa
    1,278
    Kent, WA
    <div class='quotetop'>QUOTE(KMO @ Feb 14 2007, 01:01 AM) [snapback]390085[/snapback]</div>
    Denso says,
    "The Prius's main water pump loses its source of mechanical energy when the vehicle is running on battery power alone and the engine is off. So, we developed an auxiliary electric water pump for the car. Our electric water pump provides a constant flow of heat to the cabin even when the mechanical pump is stopped. The mechanical pump operates when the engine is running, which reduces the load on the battery. And a bypass function reroutes water flow to avoid resistance from whichever pump isn't running."
  14. genalex
    genalex Member
    265
    <div class='quotetop'>QUOTE(seasalsa @ Feb 14 2007, 08:25 AM) [snapback]390114[/snapback]</div>
    The belt and suspenders school of design?
    Actually it's perfectly consistant with saving hot coolant in a thermos bottle.
