A/CBlowing Hot Air Error code DTC B1471 AC inverter High Voltage
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Tarek, Mar 17, 2025.
Tags:
  1. Tarek
    Tarek Junior Member
    25
    Tx
    I would appreciate if you can refer me how to conduct this test. Thank you in advance. I have been searching but I not sure how
  2. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    Third planet from the Sun
    Stop!
    I noticed that you have a Prius V photo on your avatar. You created a topic in the Prius Gen3 section. These cars are similar in many ways, but there are differences.
    I provided diagrams for Gen3.
    Which car is faulty with B1471?
  3. Tarek
    Tarek Junior Member
    25
    Tx
    its 2012 Prius V.
  4. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    Then the scheme will be like this.
    INSPECT NO. 2 ENGINE WIRE
    With the machine switched off, taking precautions, disconnect the connector from the inverter and compressor and check its condition. Measure the resistance of the wires from one connector to the other. This eliminates a break in the voltage supply from the inverter to the compressor.
    Also check for breakdown on the case. If the resistance does not correspond to those indicated in the table below, change the wiring harness; if it does, change the compressor.
    CAUTION:
    Be sure to wear insulated gloves.
    1. Disconnect the No. 2 engine wire connector.
    2. Measure the resistance according to the value(s) in the table below.
      Standard Resistance
      Tester Connection
      Condition Specified Condition
      E1-1 (PE) - E3-2 (ACPE) Always Below 1 Ω
      E1-2 (PB) - E3-1 (ACPB) Always Below 1 Ω
      E1-1 (PE) - Body ground Always 10 kΩ or higher
      E1-2 (PB) - Body ground Always 10 kΩ or higher
    wukong sun and Tarek like this.
