A couple of quick Q's about a 2004 2nd Gen Prius - brakes and engine use....
Discussion in 'Gen 2 Prius Accessories & Modifications' started by priusrecon, Oct 3, 2015.
  1. priusrecon
    priusrecon Member
    130
    43
    Upstate NY
    Hi guys,
    I'm looking for a quick way to tell if my gasoline engine is running or not.
    I've found that the MFD display is not always accurate on that point.
    What I want to do is rig up a simple set of lights or LED lights on my dash to indicate two
    simple things for me;
    - whenever my gasoline engine is on and running
    and
    -whenever my friction brakes are engaging as opposed to just the regenerative back braking
    from the generator. I cannot tell the difference between the two and when they are happening.
    My 2004 seemingly has no define way of indicating that to me.
    Is there a simple way to tap into the wiring and rig an indicator lamp for these two things?
    thanks,
  2. JimboPalmer
    12,470
    6,863
    Greenwood MS USA
  3. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    I use a (two actually) ScanGauge-II which shows me RPM and HP (amongst other useful things) - my second SC-II was from eBay - a very useful and easy mod! - hope this helps - Wil
