A few maintenance questions
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by southjerseycraig, Sep 22, 2023.
  1. rjparker
    rjparker Tu Humilde Sirviente
    11,049
    6,923
    Texas Hill Country
    The solution is a rebuild which makes the engine decent. Hg replacements will otherwise repeat as seen in taxi operations. Toyota used the 1.8 L 2ZR-FXE engine worldwide until 2021 in the v/+/Alpha wagons with huge numbers sold in Japan.
  2. douglasjre
    douglasjre Senior Member
    2,249
    751
    Null, NL
    What solves the hg issues?
  3. rjparker
    11,049
    6,923
    Texas Hill Country
    A better hg was engineered and vastly reduced hydrocarbon build up in the cylinders,intake, pcv and egr.
  4. Mendel Leisk
    42,305
    How would it do that? Are there any tests, studies?
  5. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Not that are available to the public, to be sure.
    The first part of his statement is undoubtedly true: A better head gasket was designed.
    Maybe as part of a "point issue" upgrade of the engine.
    The second part is pure BS as head gaskets don't contribute to carbon buildup......anywhere on
    anything.......as long as the gasket hasn't lot it's integrity (blown and leaking).
  6. rjparker
    11,049
    6,923
    Texas Hill Country
    Excessive oil consumption eliminated
  7. sam spade 2
    7,035
    2,804
    2017 Prius c
    Strike two.
    A "better" head gasket does NOT alter the oil usage........
    unless the original one has failed and sprung a leak.
    And even if that IS what happened, the oil "consumption" likely is
    not the first thing you will notice.
  8. rjparker
    11,049
    6,923
    Texas Hill Country
    Eliminated by a rebuild. I understand the reading comprehension confusion I may have caused for certain folks.
  9. Joe Garcia
    Joe Garcia New Member
    Fresno, California
  10. bisco
    52,807
    exactly my point
  11. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Hybrid battery is unbalanced and could use some reconditioning. I'd look at a charger for it. You can discharge in your driveway by putting the car in neutral and running your headlights until the engine shuts down. From past experience this is safer than the discharger (134V is too low for this car and ruins cells, 168V is better).
    You can thank Bidens homeless and illegal aliens.
    SM-A536V ?
