A few niggles on the '10
Discussion in 'Gen 3 Prius Main Forum' started by DeanFL, Jul 7, 2009.
  1. nylion
    nylion New Member
    167
    61
    Seattle WA
    In my Gen II, I thought I had this problem. Try switching from recirc to fresh air. You can be in "auto" mode and change these without leaving that mode (also can do the same with defrost). I believe that if you set recirc, the car remembers that and will maintain it until you go back to fresh air. In fresh air mode, the car decides when to recirc or not recirc.
  2. Martin37
    Martin37 New Member
    200
    23
    Joseph, Oregon
    How about puting a 'dictiionary' of warning light symbols say on the underside of the sun visor? Is there even any room? There seems to be a lot of such symbols and when and if they appear would an instant reference source be useful? Of course there is the manual.
  3. tumbleweed
    tumbleweed Senior Member
    4,067
    691
    Eastern Oregon
    According to the Owner's Manual page 465 the headlight cleaner has it's own fuse. Fuse #7 in the engine compartment fuse box. Why not try removing it? If you want the washers in the winter just put it back in. Can't try it my car isn't here yet.
  4. bob brown
    bob brown Member
    114
    17
    South Florida
    I have an '04. I know where the 'secret' drawer you refer to is, but where is the small change drawer on the left side of the drivers?
    The only thing I can see is the narrow storage slot in the center of the lower dash. Is that what you mean?
  5. DeanFL
    DeanFL 2010 owner - 1st Prius
    1,015
    355
    Leesburg Florida USA
    I think this is a great idea. Easy reference, especially when needed and for those that don't carry the owner's manual with the car.
    I was thinking about doing just that...
  6. DeanFL
    1,015
    355
    Done. Went to Ace Hardware and bought 4 flush-head Phillips screws, black with attached washer. Took 5 minutes to replace all. And the new screw does not extend nearly as far as the old bolt, but easy to remove with a screwdriver.
    A bit of irritant to me as well. Past tense now.
    2 people like this.
  7. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Nice. I didn't notice those bolt heads until they were mentioned here, but they really do look tacky. Time for a trip to Ace.
  8. dogllama
    dogllama New Member
    118
    Los Angeles
    I agree, it's one of the first things i noticed when i was walking around the car. I have white, so it sticks out like a sore thumb...
  9. zencar
    zencar Junior Member
    34
    Venice, CA
    Anyone discover the easily removable rubber window insulation? I did last night when I stuck my hand out of the window, knocked it and the whole upper section dropped out of the slot. Luckily it pops back in, but definitely reinforced a feeling of cheapness in the building (that and my ever present dash rattle).
