A friend of mine is having transmission issues. Can someone help?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Setheroth, Jun 27, 2016.
  1. JC91006
    16,769
    8,567
    I'm not, it's just very hard to find a gen2 at that mileage now.
    And if a shop told you the transaxle had 160k miles, it probably would make one think twice about it.
    It's the same when a hv battery seller says the battery only has 60k miles on it, how would you possibly know?
    Setheroth likes this.
  2. Setheroth
    Setheroth Junior Member
    25
    Charlotte, NC
    Good point. Since it's a local part, maybe my buddy could go and inspect the car himself...
    2015ToyPrius likes this.
  3. Mendel Leisk
    41,497
    I wonder what fails on the transaxles, and if early and subsequent fluid changes might have helped? And then: maybe someone did change the fluid, but decided they knew better, used something other than Toyota ATF-WS? Who knows.
    Toyota continues to insist the fluid is "lifetime", and instills this mindset in the dealerships.
  4. Setheroth
    25
    Charlotte, NC
    I am very curious about this myself, since I own a 2012 with 72k on it. Not to take this off-topic, but what sort of fluid changes do the experts recommend?
  5. Mendel Leisk
    41,497
    I'd go with the Toyota fluid. If it's never been changed, asap.
    2015ToyPrius and Setheroth like this.
  6. bisco
    51,985
    maybe someone changed the fluid religiously with toyota oem, and it still failed. maybe they drove it hard, maybe it had a very small defect from the factory, maybe 220k is average life, maybe...
  7. 2015ToyPrius
    2015ToyPrius Junior Member
    From what I read at Luscious Garage the average life of the transmission of Gen 2 was between 150k Miles and 250K miles.
  8. strawbrad
    953
    1,007
    Not really. It can not read the sub codes.
    A quick search of Car-Part.com--Used Auto Parts Market shows about 800 transmissions with less than 100K available nationwide. This shows that the failure rate on the Gen II tranny is very low.
    They have seen a small number of failures in that the range. The vast majority will go much, much farther.
    This does not match what Luscious Garage has found. They say the car will loose the ability to charge the battery.
    Gen 2 Prius (2004-2009) Transmission Failure, P0AA6, P0A92, P0A7A - Luscious Garage | Hybrid Specialists
    Here are a couple of pages from the repair manual.
    http://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/repair%20manual/04pruisr/05/21bpm/0a92606.pdf
    http://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/repair%20manual/04pruisr/05/21bpm/0a7a325.pdf
    Before spending a whole bunch of money you should be very sure of the problem. Buy a proper code reader. Follow the trouble shooting steps. Do not skip to the end.
    A cheap Mini VCI. Mini VCI 16 Pin OBD2 Diagnostic Scanner Cable for Toyota Tis Techstream US Sale | eBay
    A better MIni VCI with newer firmware. Mini VCI J2534 OBD2 USB Interface for Toyota Firmware V2 0 4 Software V10 10 018 | eBay
    A much better scanner by VXDIAG Vxdiag VCX Nano for Toyota Tis Techstream V10 10 018 with SAE J2534 Windows XP | eBay
    Brad
  9. strawbrad
    953
    1,007
    Edit, double post deleted.
  10. Setheroth
    25
    Charlotte, NC
