A List of Prius Mods for the Website
Discussion in 'Gen 2 Prius Accessories & Modifications' started by TonyPSchaefer, May 7, 2007.
  1. Prius Limo
    Prius Limo New Member
    36
    Quebec, Canada
    <div class='quotetop'>QUOTE(Tideland Prius @ Oct 6 2007, 03:46 PM) [snapback]522242[/snapback]</div>
    page 7 Post #124
  2. PoulStaugaard
    PoulStaugaard Now a PriusOwner
    95
    Copenhagen, Denmark
    To avoid scratching the rear bumper when loading/onloadig cargo, I suggest attaching a rectangular piece of leather - sheep hide, perhaps - to the rear edge of the trunk buttom cover. Folding it in/out would take almost no time, which means that it would actually be in place when it should be. The zero load lip makes it an obvious thing to do, and it could even make a nice picnic bench, albeit on the tall side.
  3. fruzzetti
    fruzzetti Customization-Obsessed
    377
    California (Pulled over 6x, ticketed 2x for tint)
    These are all excellent ideas. The seat heater makes driving the leather a dream come true, especially in the mornings.
    I think you'll have better luck with a spring+coilover setup; lowering 1.5-2cm streamlines the look quite nicely and you still rarely scrape (when you do scrape, it's still only the scrape guard).
    The next mod I'm going to put in my 06 is remote start and, if possible, remote control (via bluetooth or VPN to carpc) of the climate controls.
    ~ dan ~
    Photos
    Note: my philosophy has and always will be that "function" modifications are more important than "form" modifications and should generally be invisible.
  4. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
  5. tbirdhs
    tbirdhs Tbirdhs
    77
    River Edge. NJ
    has any one researched or purchase a velour dash cover. the glare is bad. have put in my last two cars, they realy help. $40- $50
  6. seasalsa
    1,278
    Kent, WA
    Just stay away from light colors, they cause a really bad reflection in windshield. I bought a beige one and had to throw it away.
  7. YoungOrganist
    YoungOrganist New Member
    Bahstahn MA
    2002 Prius
  8. tbirdhs
    tbirdhs Tbirdhs
    77
    River Edge. NJ
    i have purchased 2 in the past for other cars. even thought that were velour and black they were still so shiney in had to spay with flat black.
  9. perryma
    perryma New Member
    1,781
    Tennessee
  10. Steamboatsig
    Steamboatsig Member
    337
    Los Angeles
    2013 Prius Plug-in
    I have done several mods to my Prius. The most important mod so far has been to replace the really weak stock horns. The Prius seems to be a target when it comes to unsafe drivers.
    I mounted them behind the lower grill, centered between the foglamps. I used a stock hole on the radiator center support beam.
    Bluegrassman and Sezy like this.
  11. Green Scotsman
    Green Scotsman New Member
    Arizona
  12. Green Scotsman
    Arizona
    Also, does anyone know anything about putting an electric turbo on it? I have been thinking about going with a standard turbo, but I was afraid that, with out a steady flow of exhaust, it wouldn't perform. I was thinking an electric would work better. I would just have to find a way to sync it with the engine turning back on after a stop.
  13. danieltaulbee
    danieltaulbee New Member
    Providence, RI
    Way over $100: Plug-in conversion, getting you 100+ mpg. (requires additional/replacement batteries)
  14. fmi
    fmi Junior Member
    24
    Phoenix
    Thanks Sparky! Are you in Arizona? I'm in Phoenix!
  15. G_Force
    G_Force New Member
    Littleton, CO
    I've turned off the back up beep in my 2008, but cannot get the seat belt beep to quit. I followed the instructions exactly, and even got the b-on/b-off to toggle, but it still beeps. Any ideas as to what I might be doing wrong?
  16. cephas
    cephas Junior Member
    50
    Prius
    I don't like the wheels on my 06, anyone has any recommendation?
    Also, I want to try the bridgestone tires.
  17. stacyh
    stacyh New Member
    Chicago
    Bumper stickers: less than $5. Mount them on magnets so they can be removed.
  18. toby45
    toby45 Junior Member
    Central Georgia
    Does anyone know where I can find scuff plates for my 2008 Prius?
  19. skipvan
    skipvan Junior Member
    Littleton CO
    Some reccomend removing the plastic rings on the wheels. When I bought my 2005, i was told that the rings were on there because a wind tunnel test revealed some turbulance and the rings corrected that. Supposed to take 2-3 mpg away. any comments or experience with this?
  20. trey
    trey New Member
    alameda,california
    my prius 08 is just a month old, but the present carseat covers are now dirty, thanks to my 4 year old twins. does anybody know how much will i spend on leather covers??installations and all?
Loading...
