A Little help please...
Discussion in 'Gen 2 Prius Technical Discussion' started by justjeff, Jan 18, 2012.
  1. edthefox5
    edthefox5 Senior Member
    10,096
    4,836
    Clearwater, Florida
    Can't you force charge it in Park? I know the engine shuts off in N but not P.
  2. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Hi Ed. I know it seems strange, because when you're warming up it charges best in "P", but last time I tried to force charge it in "P" it would rev the engine but it wouldn't charge the battery. I had to put it into "D" to force charge it.
    Can someone please confirm this, it has been a while since I've done it (force charge).
  3. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    I vaguely remember having to force charge in "D".
  4. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Correct, the car force charges nicely in DRIVE, ( that is when the car is totally servicable) I have done it a few times, with no problems. Charges to a Green Charge in about one minute.
    :cheer2:
  5. edthefox5
    10,096
    4,836
    Clearwater, Florida
    I tried force charging it today in park and the motor revs up but I see no arrow movement in the mfd so that won't work.
    I tried it in D and it charges but it seems hard on the car powerbraking it like that for quite a while. That has to heat up the mg pretty quick.
  6. andyprius
    2,212
    188
    How quick ? And to what teperature ? :cheer2:
  7. 2009Prius
    2,705
    512
    63
    I dug up the log of force charging and plotted up:
    I did two force charges, the first time the MG2 T went from 38 C to 43C, and the 2nd time from 42C to 46C. The SOC saturated at 81.5 at which point the Prius refused to put more current into the HV battery.
  8. Frannieb14
    Frannieb14 New Member
    I have a question about my key. I have a 2007 and the other day Feb 7, 2012 one of my keys stopped working. Is there anyway to re-charge it or what. Can anyone help me?
  9. andyprius
    2,212
    188
    Putting the key in the oven at 350 degees F will recharge it, charging time 3 hours. or til medium rare. Just kidding, there is a battery in the FOB, it needs changing. Do a search on Prius Chat under FOB.:D
  10. justjeff
    justjeff Junior Member
    55
    Colorado
    Just wanted to let you all know the car is together and running. I finally tapped out and brought it to Adopt A Part. It ran like crap because the motor war junk...sucked a piece of the intake into the motor and bent the valves I guess. So replaced the motor. And the brake system had a short. So that is fixed. Eric and Brian were fair and I would recommend them. However I did have to add coolant to both systems after the work was done. But I had some at my shop so no big deal.
    Now I have two other issues I am trying to figure out. When I shut off the car, sometimes the noise after shut down isnt normal. I know because my girlfriend has a prius as well. Mine is louder at times, and sounds different. Almost like a pump is running dry....also the car seems to slip vs how my girlfriends pulls. I know the transmission can't slip like a conventional transmission, but it sure seems to pull less for the rpm's vs my girlfriends...I wonder if there is enough transaxle fluid in the car?? Anyone have any ideas?
