A look inside the Toyota 90915-YZZN1 spin on oil filter
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Georgina Rudkus, Mar 31, 2023.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,422
    2,392
    Taylors, SC
    I changed the oil in my car, today.
    Usually, I just put the oil filter into the bin at my recycling center. This time, I cut it open and examined its components.
    I was surprised to find out how high quality this Toyota filter is compared to the videos of those mass market Fram oil filters with the rusted metal and glued cardboard components.
    All the steel components are zinc plated on the inside. The drain back valve is made of silicone rubber.
    Instead of a flat spring, the over pressure relief valve is closed with a coiled spring.
    #1 Georgina Rudkus, Mar 31, 2023
    RRxing and Doug McC like this.
  2. JC91006
    16,748
    8,553
    I'm surprised their filters are still reasonably priced compared to their competitors. I've heard the quality of the filter element is the only thing that's holding the Toyota OEM filters back. They are good for about 10k miles and they've been engineered to just meet that threshold.
  3. Doug McC
    Doug McC Senior Member
    1,063
    405
    Midwest
    2022 Prius
    Why design and build a filter that goes beyond what is required for the mechanical device it is designed to protect? A waste of resources it seems to me, BTWDIK?
    Zeppo Shanski likes this.
  4. Georgina Rudkus
    3,422
    2,392
    Taylors, SC
    That filter came out in 6 months and only after 1,200 miles.
    If one wants to keep his or her car for a long time, 3,000 to 5,000 miles is the maximum you'd want to keep oil in an engine.
    There is no such thing as an extended life motor oil and filter. The longer it's in use, the more detritus, gasoline dilution, and varnish from burned and unburned hydrocarbons there is to gum up and abrade the wear surfaces within the engine.
    The only way to get rid of these is to drain the oil, change the filter and install new oil.
    Zeppo Shanski, Doug McC and RRxing like this.
  5. Mendel Leisk
    41,101
    Now I don't feel too bad, regarding our 6 months and ~1500 kms.
  6. Georgina Rudkus
    3,422
    2,392
    Taylors, SC
    The internal filter is basically the same as the cartridge element.
    Using the cheap cutoff tool that I got off Amazon, it takes no time to cut the spin on can open to recycle the steel components.
