A Modest Proposal To Solve The TPMS Problem
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Voltan, Jul 14, 2010.
  1. bagwell
    bagwell Active Member
    592
    49
    the woodlands, tx
    so has anyone tried just having the sensors in the car and reset them????
  2. RobH
    RobH Senior Member
    2,376
    988
    70
    Sunnyvale, California
    The sensors just send the current absolute pressure and temperature. The ECU compares the pressure value to an alarm value, and turns on the light if the value is too low (or if the sensor is missing). Pressing the reset button tells the ECU to set the alarm value to about 8 pounds less than the current value (subject to that minimum).
    I added a sensor to my spare and reprogrammed the ECU for 5 sensors. While fiddling with it all, my TPMS light was ON until I did a reset with full pressure in the spare.
  3. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    I know I've seen online a writeup about putting these in a PVC tube.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    And pressurizing it.
    Tom
  5. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    A PVC pipe turns into shrapnel if broken under pressure. probably not such a big deal at a lowly 30-35psi, but a couple of wraps of duct tape around it to restrain potentially flying bits would be a good idea.
    People have been seriously injured by PVC pipe used to route compressed air around a shop.
  6. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    This is the 5th thread that this topic has come up. Here are the pics again.
    Both work. You need to put the sensors in a pressurized chamber. In both pics they have one nozzle exposed incase the pressure drops.
  7. Judgeless
    1,821
    257
    Cleveland, OH
    The PVC you buy at Home Depot or Lowes is rated for 280PSI. I am sure that number is very conservative. If you put 30-50PSI in the tube you have nothing to worry about.
    Here is a pic if a PVC air gun I built. It uses 4†and I pressurize it to 150PSI.
