a new document for Prius... PSD
Discussion in 'Gen 2 Prius Main Forum' started by john1701a, Mar 26, 2005.
  1. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    I built the Visible Engine when I was in high school I wish we had a Visible HSG to play with. Mine had a electric motor to turn over the engine. That was the high water mark of my automotive repair experence.
  2. john1701a
    john1701a Prius Guru
    12,840
    5,311
    58
    I revealed the document; however, I'll still be doing tweaks for awhile.
    Just now I (finally) remembered why 10kW motor (MG1) isn't only called a "generator". That's because the "motor" part of it is used for starting the engine!
    So... I'll add some text about that.
  3. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    I ruined mine when I used vegetable oil to lubricate the moving parts, not thinking that vegetable oil gels.
  4. Dr.Jay
    Dr.Jay New Member
    55
    South Jersey
    Here's a little did-bit of information.
    Many may have seen this before but here's a quote from an older document I ran across. . .
    The Planetary drive was actually was invented in 1921. . .guess no one knew how to implement it until now.
    ..."check out US patent number 1558806, applied for by a Mr. Hess of Union, Oregon in 1921. Not to take away any of the elegence of Toyota's design, but Mr. Hess was a little ahead of his time! It's all there, the planetary gear power divider, the electric motor/generators, batteries, engine etc!"
    The doc also goes into the many patents Toyota got on the engine, etc.
  5. john1701a
    12,840
    5,311
    58
    The fuel-cell was invented back in 1839.
    165 years later, they're still trying to figure out how to take advantage of it.
  6. Frank Hudon
    Frank Hudon Senior Member
    4,147
    and make it last longer than about a thousand hours! Just had the head off a Toyota forklift and it had 14,700 hours on it since new. Checked the service history since new and this is the first major engine problem.
